Output/recording/DTXpress III S
2004-09-15 by Mr
Hello and thanks in advance for any help. I'm recording direct to my
Tascam 388 and although I have both the internal and knob volume
maxed out I'm still not getting a strong signal. I get a stronger
signal (still not good enough) going from the module headphone jack
out to the board. I have to put the faders on my Tascam all the way
up and still the meters barely register the kit. Now, I've been going
through a compressor which has boosted the signal enough, but still I
should not have to go through a compressor, there should be plenty of
signal going direct from the outs of the module. Any ideas?
Eddie
Re: Output/recording/DTXpress III S
2004-09-15 by emf
my
going
I
of
> Thanks,
> Eddie
Eddie,
Did you raise the Drum Kit Volume in the Common parameter area of the
Voice Edit Menu?  If you're using the Live, as opposed to Practice
setting, you don't have the knobs on the front of the module in low
positions, do you?
Ed
Re: [DTXpress] Output/recording/DTXpress III S
2004-09-15 by Stuart McConaghy
Eddie,
You don't have a problem, seriously. The headphone output already sends
out a compressed and pre-amplified signal, which is why it's louder.
The pre-amplification and compression changes the sound character,
since it's being optimized for a set of headphones, and that makes it
difficult to use in a recording setting in conjunction with the other
outputs.
You say you have all the volume settings at maximum, that's totally
alright, as long as you're not experiencing any clipping (i.e. digital
signal distortion, a very harsh signal degradation, as opposed to
analog harmonic distortion, which makes guitars sound nice and creamy),
you'll normalize and compress the signal anyway, like  99% of all
people who record electronic (or even acoustic) instruments. An output
signal that's very low is always more flexible than a signal that's way
too high, because after a while signal doesn't really get louder, it
gets more distorted. I rarely turn electronic modules up higher than
maybe 70%, it just isn't necessary since, in a recording setting, I'll
most likely normalize the signal towards the end, anyway, which will
raise the volume level.
If you're viewing this as a problem, check your recorder's manual for
normalization of audio files, and use a subtle compression to raise the
levels.
Believe me, as an engineer, I'd rather work with a signal that's very
low, because there's more I can do with it. You can't remove distortion
from a signal, you know.
Stuart McConaghy
> Thanks,
> Eddie
> Community email addresses:
>   Post message: DTXpress@yahoogroups.com
>   Subscribe:    DTXpress-subscribe@yahoogroups.com
>   Unsubscribe:  DTXpress-unsubscribe@yahoogroups.com
>   List owner:   DTXpress-owner@yahoogroups.com
> Shortcut URL to this page:
>   http://groups.yahoo.com/group/DTXpress
> Alternate DTXpress site:
>   http://www.dtxpressions.com
<image.tiff>
<image.tiff>
> • 	To visit your group on the web, go to:
> http://groups.yahoo.com/group/DTXpress/
> • 	To unsubscribe from this group, send an email to:
> • 	Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2004-09-15 by perhasv
I'd have to disagree with Stuart on a couple of points:
First of all, (as an engineer) I'd rather have a correctly level
than a distorted or a too low level.  True, you cannot undo a
distorted signal (shit in = shit out), and you may amplify a weak
signal.  But, as you amplify you also amplify the noise in the
signal and if it is a digital recording, you get a distortion of the
levels as you have only used a small number of bits to store the
information.  The best is to find out why you only get low signal
levels and then follow stuart's advice on using approx 70% of max on
the average signal level.
I don't know the DTXpress module well enough to comment on the
various settings that might be causing the problem, but if you are
sure these are correct, I would recomend that you disconnect all
devices after the sound module and check the cables on a device that
you know work well and provide a line level signal (a CD player).
If you are sure all settings in the menus of the sound module are
correct, the cables are OK and you still don't get the right level
signal - then you do have a problem!  (You have checked that there
is nothing wrong with the input of the recorder? - a line level
signal on an input for mic or other signal levels may give you such
problems).
If the signal from the sound module is OK, then you proceede through
your chain of devices and cables and identify where it goes wrong.
Best of luck!
PerH
--- In DTXpress@yahoogroups.com, Stuart McConaghy <stuart@s...>
wrote:
> Eddie,
sends
louder.
it
other
> outputs.
totally
digital
creamy),
output
that's way
it
than
I'll
will
for
raise the
> levels.
very
distortion
> Stuart McConaghy
to my
jack
way
going
still I
plenty of
> > Thanks,
> > Eddie
> <image.tiff>
> <image.tiff>
> > Yahoo! Groups Links
of
Service.
