EXPress III Headphone Output Low
2004-09-15 by Tom
I tried an Express III kit in the store and the headphone output was
pretty low.   I had it at full volumn and it was just comfortable
for easy listening.   Occasionally, I might want to crank it up, and
there was no headroom to do that.   Is this typical for an EXPress
III module?
TomBrooklyn
Re: EXPress III Headphone Output Low
2004-09-15 by oldguydrummer
was
and
> III module?
> TomBrooklyn
Tom,
If you have a long weekend and could go back through the archive of
posts here,you will find that this is typical going all the way back
to the original Dtxpress I. Even with the pads all set at 127 and the
kit volume set at 127, you still may not find the volume to be
enough, even though many folks do. It just depends on what type of
music you are playing along with. One thing to consider is that the
headphones in the store are probably not the best at isolation and
may not even be closed back, so that you would still here the strikes
on the drum pads. With easy listening music, a good set of headphones
maybe all you need. Others have picked up a small headphone amplifier
or if you pickup an amplifier/monitor, you can simply run the module
through the amplifier/monitor and plug you headphones into the amp,
and get more than enough volume for play even the hardest rock.
OGD
Re: [DTXpress] Re: EXPress III Headphone Output Low
2004-09-16 by Creighton Higgins
My AKGs are plenty loud- different phones have different impedances
and efficiency. It can be as simple as matching the headphones to the
unit.
Creighton
On Wed, 15 Sep 2004 23:29:07 -0000, oldguydrummer
> was
> and
> > III module?
> > TomBrooklyn
> Tom,
> OGD
> Community email addresses:
>   Post message: DTXpress@yahoogroups.com
>   Subscribe:    DTXpress-subscribe@yahoogroups.com
>   Unsubscribe:  DTXpress-unsubscribe@yahoogroups.com
>   List owner:   DTXpress-owner@yahoogroups.com
> Shortcut URL to this page:
>   http://groups.yahoo.com/group/DTXpress
> Alternate DTXpress site:
>   http://www.dtxpressions.com
Creighton Higgins
2004-09-18 by Tom
the unit.
I have Byerdynamic 880s at home.   BTW, they're the best sounding
headphones I've ever listened to this side of $2000 Stax
electrostatics.
Come to think of it, it might not be a bad idea to take my own
headphones with me when I go shopping again.
I'm not sure what the impedance on them is.    Unless I'm mistaken,
the lower the impedance, the more power they will suck out of the
source.   There efficiency would make a difference too I suppose, if
they're like loudspeakers.
Plugging them into an amp like oldguydrummer said would probably
work too anyway.   I hadn't thought about that.     I am shopping
for my first ekit now.
Tom
