RE: [DTXpress] DT Express II Configuration - Help me with this on e, somebody!
2004-10-11 by rdamon@mckinney-usa.com
There is a menu item under the utilities that will swap out input 1 with
9/10 made just for the purpose you describe. Just move the KP65+tom5 to
input 9/10 and the crash to input 1. The signal coming from physical input
no.1(crash) will be redirected to input 9 and the signal coming from
physical input no. 9 (kick)  will be redirected to input no. 1.
If you were not having any crosstalk problems before you moved the TP65,
then it is probably from having to hit the Zenbal harder that is causing the
crosstalk now. You may have to just set the specific rejection between the
hihat input 8 and the snare input 2 or move the hihat pad to the alternate
mounting location on the mounting tube with the module. You will have to
setup input no. 10 and set it for the correct pad type and set the rejection
settings based on where you mount the pad on the rack.
As far as it not being loud enough, have you tried to adjust the volume for
the pad higher, or tried changing the velocity curve?  I don't believe their
is a attenuation switch for that input on the back of the module. Is there a
sensitivity adjustment screw on the Zenbal, like there is on the Yamaha
pads?
I don't have the manual in  front of me, so I can't give a more precise
answer than that until later tonight.
OGD
   _____
 Sent: Monday, October 11, 2004 2:34 PM
To: DTXpress@yahoogroups.com
Subject: [DTXpress] DT Express II Configuration - Help me with this one,
somebody!
Let me give you the before and after on my mission here.
I just bought a Pintech Zenbal single zone High Hat to replace the
TP65 Yamaha pad that came with the set (I didn't like the unnatural
feeling and shape of the TP65). I now want to use the TP65 as
another Tom.  Currently, Input 9/10 is being used for another Crash
cymbal I bought separately.  Hence, all of the inputs behing the
module are populated.  Because the end result of this upgrade is
that I've added one pad to my configuration, the only place it can
plug into is the input jack on the KP kick pedal.  The instructions
say to utilize that, a cable from the output on the KP MUST connect
to Input 9/10 on the module.  To do this, I must now unplug the KP
cable from Input 1 and move it to Input 9/10 to get that extra Tom
working.  However, that also means I have to unplug the current
crash cymbal in Input 9/10.  I still want to use that as well, but
the only available Input now is Input 1 (the now-empty labeled Kick).
My questions are:
1.  How do I permanently "remap" Input 1 (labeled Kick) to now be a
Crash Cymbal.  By permanent, I don't mean just creating my own kit
and storing it as Kit #49 or #50.  I mean, if I chose to play kit
type "Big Reverb" the crash cymbal would make a cymbal noise - not a
bass drum noise that the module thinks is connected to it.  I'm sure
there's a way to do a permanent remap - I just don't understand how
to do it.
2.  I kind of know how to configure Input 9/10 now to be both a bass
drum and a tom, but I have the same kind of question.  How do I
permanently remap that configuration so if I chose to use a canned
pre-set kit type, like Big Reverb or Rock Dry 2, the module will
play a bass drum sound when I kick - not a Cymbal.
3.  My new Pintech high-hat is, out-of-the-box, very quiet and I
have to hit it hard to get a decent sound out of it.  How do I
manipulate that non-Yamaha cymbal to produce a nice heavy Hi-hat
sound without having to swing hard at it.
4.  I'm also getting a fair-amount of cross talk when hitting the
new hi-hat.  I'm hearing the newly added Tom (TP65) and the snare
drum as well when striking the Hi-hat.  I think there are some
rejection settings there that may work for this, but it's unclear.
The information transmitted herewith is sensitive information intended only
for use to the individual or entity to which it is addressed. If the reader
of this message is not the intended recipient, you are hereby notified that
any review, retransmission, dissemination, distribution, copying or other
use of, or taking of any action in reliance upon, this information is
strictly prohibited. If you have received this communication in error,
please contact the sender and delete the material from your computer.
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
Re: DT Express II Configuration - Help me with this on e, somebody!
2004-10-11 by jggallow
Old Guy:
Thanks for your response.
I have my manual with me at work, but I'm not seeing any UTIL mode
that talks specifically about swapping those two Inputs.  Is it
called a "swap" or "remap" command?  I don't think it's the Map Copy
command - that's more about copying a preset drum kit source to
another location.  Is it the Pad Type setup under the Trigger Setup
Edit Mode?  I don't think that's it either....
If you have any more specifics on how to do it, or what the name of
the UTIL command is, I'd greatly appreciate.
In regards to the crosstalk, the new hi-hat snare and extra tom are
all connected to the "snare bar."  Are the vibrations causin that
crosstalk.  maybe I should mount the h-hat on an old stand.  Would
that help?
1 with
KP65+tom5 to
physical input
from
TP65,
causing the
between the
alternate
have to
rejection
volume for
believe their
Is there a
Yamaha
> pads?
precise
> OGD
>    _____
> From: jggallow
this one,
> somebody!
unnatural
Crash
instructions
connect
Kick).
> My questions are:
a
a
sure
how
> to do it.
bass
intended only
the reader
notified that
or other
is
error,
computer.
_
System.
_
