Thanks, OGD. I am much obliged. I'll spend some time following your
instructions and see how I go. A pity there isn't a DTXtreme
version of the DTXpressions site, then we could post them there for
other first-time DTXT users.
--- In DTXpress@yahoogroups.com, "oldguydrummer" <rdamon@m...> wrote:
> Nick,
> Here goes nothing, it should be clear as mud when I finish, as I
am
> still trying to figure out why they did it this way.
> When you go to the Voice menu, and you turn the first knob
[Voice1]
> counterclockwise until you see the lowest midi note number/name
13C#-
> 1, the Type = Percs1; the Voice=SurdoM.
> As you scroll up through the midi note number/name list from 13C#-
1
> (which is note number 13 and midi note C#-1) up to note
number/name
> of 94A#5 (which is note number 94 and mide note A#5) that a
different
> instrument group and voice number is assigned to each mide note.
> There are a total of 82 assignable note numbers 13 through 94 (C#-
1
> to A#5) for this module. The note numbers 0-12 and 95-127 cannot
be
> used for pad voices, but only for mide control events [see page
42,3-
> Note#, under Settings, *note number].
> The module comes with these notes already preset so they can be
used
> with the factory preset drum kits. So if you only what to use the
> factory drum kits and just do some minor tweaking of the voice,
you
> can just change it here, and that is as far as you need to go.
Just
> remember, if you change an assignment to a midi note here that has
a
> asterick beside it, it will change the midi note/name for all the
> kits that use that midi note number.
> For the more adventure-some, multiple voices layered per pad:
> Start by going to the Trigger menu item [TrgMIDI1].
> For each Input 1-16 (pads), 1R1-8R2 (rims), that you want to setup
> with more than one voice make sure that the second item on the
menu
> is set to "Stack".
> Now go to the Trigger menu item [TrgMIDI2].
> The first item is the trigger Input source 1-16 or rims.
> The second item is the Note number, 1st,2nd,3rd,4th, etc.
> For pads you can stack 6 notes or 9 alternate mode notes.
> For the Hihat you can stack 5 notes.
> For the rims you can stack 2 notes.
> The second knob scrolls down through the note 1st, 2nd, 3rd...6th,
> etc. This is similar to the layer number on the Dtxpress module,
> except you have more than 2 layers.
> The third item is the actual midi number/name (13C#-1) that you
> assign to each "Note" or "layer". So for example, if you set "Note
> 1st" to equal 13C#-1 and "Note 2nd" to equal 14D-1, you will
> have "Layer" 1 set to play "Percs1/SurdoM1" and "Layer" 2 set to
> play "Percs1/Surdo".
> And that's really all there is to it. In the Trigger menu you tell
> the module how many and what midi notes you want it to play for
each
> trigger input 1-16 and rims. You then go to the Voice menu and
assign
> the actual sounds to the midi notes that you are using.
> Example:
> Setting up the snare pad to have three layered voices.
> First check to see which midi number/names are not being used in
> Voice menu. They are the ones that do not have a * beside the note
> number. In this case we are going to use the following three midi
> note numbers and assign them the following Type/Voices:
> [Voice1] TYPE VOICE
> 13C#-1 AcSnr1 St.Smith1 (this will be layer 1 voice)
> 14D-1 AcSnr1 St.Smith2 (this will be layer 2 voice)
> 15D#-1 AcSnr1 St.Snare (this will be layer 3 voice)
> Now go to the Trigger Menu [TrgMIDI2]
> For the first item select "Input=1", which is the snare pad.
> For the second item select "Note = 1st", which is the first
layered
> note.
> For the third item select "Note# = 13C#-1"
> Now set the second item to "Note = 2nd", which is the second
layered
> note and set the third item to "Note# = 14D-1"
> Now set the second item to "Note = 3rd", which is the third
layered
> voice and set the third item to "Note# = 15D#-1".
> Then save it to a user kit and your done. You can now go through
and
> adjust the volume and crossfading in a similar fashion to the
> Dtxpress module, except this is done in the Trigger menu instead
of
> the Voice menu.
> Hope that helps you get started.
> OGD
> --- In DTXpress@yahoogroups.com, "Nick Carroll" <njcarroll56@y...>
> wrote:
> > Cheers, and thanks OGD. I really do need a hand to decipher the
> > handbook instructions, which I must have skipped over several
times.
