Midi recording with multiple modules?
2004-12-01 by zapaxe
Recently been learning midi and since I have multiple modules, I was
thinking about midi recording.
Would I have to send 'each' module to a separate midi track into my
Cubase computer? Or can I link module #1's midi out into modules
#2's midi in, then module #2's midi out to my sound card?
I'm wondering about playing back the recorded midi from my Cubase
computer, back to the modules. I mean the Cubase drum editor has
specific lines for each drum, cymbal etc...So I'm guessing that
sending each module into the computer separately would be the way to
do it...?
Btw, my main reason for multiple modules is obviosly to have a
number of trigger pads to beat on for different sounds:)
Steve
Re: Midi recording with multiple modules?
2004-12-01 by beeoof2
Steve,
Which version of Cubase are you using?  If you have SX and a
multi-port midi intreface, you can choose an independent midi
input for each MIDI Track.  You can simply record enable 2
tracks, each channel 10, but coming from and going to their own
MIDI port on the interface (disable midi thru or turn DTX Local
Off).
If you are using only one midi input to your computer such as
found on a built-in sound card, you will need to set the cables as
you mentioned (again with Cubase' midi thru off or DTX local off)
and just record all the notes onto one track.  You might find that
the 'doubling-up' effect I mentioned in answer to your last
question may be a problem when looking at the edit windows.
What'll happen is Cubase won't know which note #'s came from
which "kit".  If you want maximum flexibility when editing your
parts then I would try to set one of the modules to send on a
different midi channel (other than 10, negating any "doubles").
Set up one midi track with its channel setting set to "Any"
allowing it to 'listen' to both kits.  You can separate the kits after
you record with the "Dissolve Track" midi command.
If you need to record midi with doubled notes you can, but realize
when you play that track back ALL notes will be doubled!  Not just
the ones played from the OUT module.  If doubles are crucial to
your sound it is better just to record your performance as audio if
that's an option.
Hope these answers are helpful, happy e-drumming!
TomTom
--- In DTXpress@yahoogroups.com, "zapaxe"
modules, I was
into my
modules
Cubase
editor has
the way to
> do it...?
> Steve
Thanks Tom,
Hmmm...either way sounds like a challenge, and I do mostly record my
drums in audio, so this would be easy as usual except NOW I have
three modules.(only two hooked up now).
I'm using Cubase VST/32 5.1 and I have an Aardvark Q10 with a single
midi in/out. But I've been using the 'To Host' midi cable to the
back of my computer with my DTXpress I kit, so I actually have my
regular midi at the Aardvark sound card free to use...I 'think' I
can use the 'To Host' and reglar midi at the same time!...? Of
course when I begin using my 3rd module? Eh, more complicated! I
would then need a multi-midi thing...UNLESS I use two 'To Host'
cables, then my regular midi?
The midi in/out/through option I've never tried and this doubling?
Sounds like a mess. I've only just begun to use midi and only
experimenting with it at this stage.
Thansk again, Steve
--- In DTXpress@yahoogroups.com, "beeoof2" <tomg@o...> wrote:
> Steve,
> Off).
after
if
> that's an option.
> TomTom
> modules, I was
> into my
> modules
> Cubase
> editor has
> the way to
> > do it...?
> > Steve
Re: [DTXpress] Re: Midi recording with multiple modules?
2004-12-03 by Tom Griffin
You should be able to use the Q10 midi and the "to Host" midi together
without a problem.  If you want to use 2 "To Host" connections then you may
have to set a separate DEVICE ID for those modules, because even though they
may be on individual serial ports, they share the same driver.  As you are
"only experimenting at this stage" let me say that midi (along with a solid
knowledge of how your modules and synths respond to midi) will offer you a
lot of creative flexibility without taxing your system as much as audio
does.  Especially when you get into sequencing other instruments besides
drums.  Happy playing!
TomTom
Reply-To: DTXpress@yahoogroups.com
Date: Wed, 01 Dec 2004 16:28:49 +0000
Subject: [DTXpress] Re: Midi recording with multiple modules?
Thanks Tom,
Thansk again, Steve
> Steve,
> Off).
after
if
> that's an option.
> TomTom
> modules, I was
> into my
> modules
> Cubase
> editor has
> the way to
> > do it...?
> > Steve
Community email addresses:
 Post message: DTXpress@yahoogroups.com
 Subscribe:    DTXpress-subscribe@yahoogroups.com
 Unsubscribe:  DTXpress-unsubscribe@yahoogroups.com
 List owner:   DTXpress-owner@yahoogroups.com
Shortcut URL to this page:
 http://groups.yahoo.com/group/DTXpress
Alternate DTXpress site:
 http://www.dtxpressions.com
Yahoo! Groups Sponsor   ADVERTISEMENT
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/DTXpress/
<mailto:DTXpress-unsubscribe@yahoogroups.com?subject=Unsubscribe>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
2004-12-04 by zapaxe
Hi Tom,
I did try to use both regular midi and the 'To Host' at the same
time and though it was touch & go, it worked.
The 'To-Host' I especially like because it free's up my midi
connection on my Aardvark card for my keyboard/synth without buying
a multi-midi device.
As far as I can tell, the 'To Host' works just like any midi
connection as far as getting midi to & from...Though I'm just
beginning in the midi world.
I don't like to plug and unplug things in my studio since I play
several instruments. I like to just pick up my guitar or bass, sit
at the drums or keyboard etc, and pick something up and just
play/record!
I actually find the 'To-Host' pretty cool, especially since it's
only ONE cable to deal with! My studio is all cables already! :/
I 'think' my Alesis keyboard also as a 'To Host' of some sort? I'd
like to look into the option of using the 'To Host' on both my
DTXpress modules, but I'm led to believe that regular midi
connections offer more than 'To Host'? Not sure what this may be...?
This separate ID you speak of???...Not sure what or how to do
that...I didn't even know this existed!:o But I'll take a look when
I get to this stage of using 2 "to Host's".
Yep, experimentation is a good way of learning:)
Thanks again, Steve
together
then you may
though they
you are
with a solid
offer you a
audio
besides
> TomTom
> From: zapaxe <a_zapelectric@h...>
> Thanks Tom,
my
single
> Thansk again, Steve
> > Steve,
> > Off).
as
that
> after
realize
just
> if
> > that's an option.
> > TomTom
> > modules, I was
> > into my
> > modules
> > Cubase
> > editor has
> > the way to
> > > do it...?
> > > Steve
