Multi-Pad trigger units connected to DTXpress modules?
2004-12-03 by zapaxe
Hi, just wondering if some of these multi-pad units such as a Roland SPD-6 Percussion Pad, ROLAND OCTAPAD Pad-8, Roland SPD-20 Percussion Pad will work with a DTXpress module or even an Alesis DM Pro module? I see that some of these have their own internal sounds too, don't know how good though! Any OTHER multi-Pad idea's models, makes, where I can see one, read about it that are just simply multi-pad units with no sounds that can be connected to a drum module? Thanks, Steve
2004-12-03 by emf
--- In DTXpress@yahoogroups.com, "zapaxe" <a_zapelectric@h...> wrote: > > Hi, just wondering if some of these multi-pad units such as a Roland > SPD-6 Percussion Pad, ROLAND OCTAPAD Pad-8, Roland SPD-20 > Percussion Pad will work with a DTXpress module or even an Alesis DM > Pro module? > > I see that some of these have their own internal sounds too, don't > know how good though! > > Any OTHER multi-Pad idea's models, makes, where I can see one, read > about it that are just simply multi-pad units with no sounds that > can be connected to a drum module? Hart's Multipad is just what it sounds like, and Alternate Mode's TrapKat is an elaborate system with its own grooves, layering, etc. The Kat MIDI lineup may be overkill for drummmers with tin ears or little melodic capability, and it's expensive. But it is fantastic. Any pads with FSRs or piezos that can be connected to the module directly via 1/4" jacks or via an intervening MIDI cable can access its sounds.
2004-12-04 by zapaxe
--- In DTXpress@yahoogroups.com, "emf" <liberatusvirus@y...> wrote: > > --- In DTXpress@yahoogroups.com, "zapaxe" <a_zapelectric@h...> wrote: > > > > Hi, just wondering if some of these multi-pad units such as a > Roland > > SPD-6 Percussion Pad, ROLAND OCTAPAD Pad-8, Roland SPD-20 > > Percussion Pad will work with a DTXpress module or even an Alesis > DM > > Pro module? > > > > I see that some of these have their own internal sounds too, don't > > know how good though! > > > > Any OTHER multi-Pad idea's models, makes, where I can see one, read > > about it that are just simply multi-pad units with no sounds that > > can be connected to a drum module? > > Hart's Multipad is just what it sounds like, and Alternate Mode's > TrapKat is an elaborate system with its own grooves, layering, etc. > The Kat MIDI lineup may be overkill for drummmers with tin ears or > little melodic capability, and it's expensive. But it is fantastic. > Any pads with FSRs or piezos that can be connected to the module > directly via 1/4" jacks or via an intervening MIDI cable can access > its sounds. Hi and thanks again, Yeah, I've been looking at different options just to see what's out there for my ever expanding system. Basically, since I have the 3 modules, I'm looking at getting more trigger pads & filling in more trigger inputs. I'm not interested in having a multi-pad with it's own sounds so much though. This idea of one of those multi-trigger pads was a thought for sounds that I would not consistantly use such as sounds FX's, Cow Bell, etc...I like the idea of the regular Yamaha pads for the normal things like snare, toms etc and set up more like a set though. So this Hart's Multipad is just a multi-trigger pad? Now if this multi-pad has individual trigger outs for each pad sp that I can run them to my modules, then this may be what I'm looking for. Or I suppose I can buy more Yamaha pads, especially one of the bar pads with 2 triggers on them which would be great for a cow bell or wood block sample and sound FX's, but damn for so little their pricy. I'm always scowering ebay for used pads for a reasonable price:) I'll have a look at this Hart's thing! Thanks, Steve
