Bass Amp, Bass Speakers: What do you think?
2004-12-10 by Tom
I don't have an ekit yet but hope to get one soon.
I have a Peavey 250 watt bass amp and two bass speaker cabinets, a
Hartke 410 (4 10" speakers) and a Gallien Krugger 15".   I was
thinking the Peavey amp with the 410 might work pretty good as a
drum monitor setup, at least for the drums although it might not
reproduce the cymbal frequencies optimally.  Anyone ever try a setup
like that?
I'll just be using this for home practice.
TomBk
RE: [DTXpress] Bass Amp, Bass Speakers: What do you think?
2004-12-10 by Ken Bracey
I'm using a Yorkville 50B bass amp (50 watts, 10 inch speaker) for my
monitor. Although this amp is really not powerful enough for the Yamaha
DTXpress III sp kit, I'll have to make do on my limited budget. This amp is
good enough however for what I need and it's nice to play without headphones
and to get the feel at the drums from the amp. The bass amp is loud enough
to make the windows rattle if I want to but at that volume it sounds like
crap and forget about getting any good sound from your cymbals... the bass
amp isn't good enough to produce the frequencies required for the cymbals.
Besides, the cymbal sounds from the DTXpress kit pretty well suck anyway
(just my opinion!). My kick predal sounds great however and I can get decent
snare and tom sounds from the amp...gound enough to practice with anyway. If
I had a choice, I'd look for a good keyboard amp next time around.
Ken
Sent: December 9, 2004 9:44 PM
To: DTXpress@yahoogroups.com
Subject: [DTXpress] Bass Amp, Bass Speakers: What do you think?
like that?
TomBk
Community email addresses:
  Post message: DTXpress@yahoogroups.com
  Subscribe:    DTXpress-subscribe@yahoogroups.com
  Unsubscribe:  DTXpress-unsubscribe@yahoogroups.com
  List owner:   DTXpress-owner@yahoogroups.com
Shortcut URL to this page:
  http://groups.yahoo.com/group/DTXpress
Alternate DTXpress site:
  http://www.dtxpressions.com
Yahoo! Groups Sponsor
<http://us.ard.yahoo.com/SIG=129beu5d3/M=324847.5707096.6763800.3001176/D=gr
plch/S=1705031972:HM/EXP=1102733105/A=2343726/R=0/SIG=12i5ktd16/*http://clk.
atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1102646705444154>
plch/S=1705031972:HM/EXP=1102733105/A=2343726/R=1/SIG=12i5ktd16/*http://clk.
Get unlimited calls to
U.S./Canada
<http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/&time=11026467
05444154>
<http://us.adserver.yahoo.com/l?M=324847.5707096.6763800.3001176/D=grplch/S=
:HM/A=2343726/rand=986923983>
  _____
Yahoo! Groups Links
*	To visit your group on the web, go to:
http://groups.yahoo.com/group/DTXpress/
*	To unsubscribe from this group, send an email to:
<mailto:DTXpress-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
Re: Bass Amp, Bass Speakers: What do you think?
2004-12-10 by emf
setup
> like that?
Tom,
Some bass amps have extended frequency response. See if you can check
the specs of your Peavey. If it doesn't go above upper bass or lower
midrange, your e-kit won't be getting its due. Of course, none of
this will mean a lick if the cabinets can't reproduce anything but
bass frequencies. If you take the higher frequencies out, you'll lose
a lot of the kit's life, even if you don't particularly care for the
cymbal sounds. You'll also lose transients from the snare.
Ed
Re: [DTXpress] Re: Bass Amp, Bass Speakers: What do you think?
2004-12-10 by Charles Baer
You could pick up an inexpensive crossover that would let
you use what you have for the high-energy bass requirements
and use/get a smaller (lower cost) setup for the higher freqs.
Charlie
>setup
>>like that?
>Tom,
>Ed
2004-12-10 by S-E-A
You could alway add pizeo tweeters (horn, or bulliet design - choice is
yours) to extend the top end providing there's room to fit them.
You will need to add a resistor in series to the pizeo's BTW.
Good thing about them;
1) Reasonably cheap
2) Normally 'idiot proof' (unless you get a new breed of idiot)
The bass amp will handle the toms, and kicks with easy.
the Sonic Energy Authority - a sound investment
2004-12-13 by Tom
> ---"Tom" wrote:   I have a Peavey 250 watt bass amp and two bass
speaker cabinets...What do you think?
check the specs of your Peavey. If it doesn't go above upper bass or
lower midrange, your e-kit won't be getting its due. Of course, none
of this will mean a lick if the cabinets can't reproduce anything
but bass frequencies.
The Peavey Amp I have is the Mark VI Series and is about 12 years
old, although it has hardly any use on it.   I didn't dig up the
specs on it yet, but it has a built in equilizer with the top band
centered on 10kHz.  It also has a built in crossover adjustable
between 200 and 2000 Hz and I do have a spare stereo amp laying
around here.
I'll have to look into the freq response of my GK410 Bass Guitar
cabinet, although I don't expect to find it will be high enough for
optimal sound.   I also have a couple of EV PA type speaker cabs
with a big horn and 15" drivers, but they're rediculously big for my
living room where I want to set up the drums.
Does anyone know the frequency range of cymbals including the
overtones and harmonics etc?
TomBk
2004-12-13 by emf
> around here.
The amp definitely goes beyond bass range and approaches, if not
actually reaches, cymbal frequencies. If it will drive at least one
other small speaker of some kind and cross over to it in the upper
bass or lower midrange, your current situation might be good enough
to satisfy you. Your ears can decide. In the best scenario, you could
mount a couple of satellites on the rack or on stands and treat the
bass cabinet as your subwoofer, crossing over at a frequency that
protects the sat(s) from overload.
If you really want the cymbals to sing, however, you shouldn't tap
out at much lower than around 16 kHz. If you're my age, you probably
can't hear frequencies any higher than that point, anyway. If your
current amp won't go that high, you might use a second one to drive
sats that overlap your bass speaker at their bottom end, say, 100 kHz
or so, thus avoiding a separate crossover altogether (though it's not
always easy to integrate sats/subs without leaving a hole in the
sound no matter what you do). A separate amp for bass and another for
the rest of the frequency range (down to 100 Hz or so) would at least
ensure that the sats don't get pushed beyond their limits if they're
driven by the same amp as the bass w/o a crossover.
Ed
