RHH-130
RHH-130
2005-01-19 by rdarby1st
Hello & greetings E drum experts.
Has anyone had experience of the new RHH-130 Hi Hat that comes with
the DXTpress III & DTXtreme IIs? If so how does it perform by
comparison with the standard, tom pad driven, set up on the standard
DTXpress III (which I find very hard to play properly - could be a
technique issue)?
I have been trying to use downstroke/upstroke technique on my
standard set up & owing to the pads shape & lack of rim switch it
just sounds pants. Apparently the RHH-130 has dual region switching
so it should be more suitable for this technique.
Also can the new PCY 150S tripple zone cymbal be used in both the
crash & ride sockets of the DTXpress brain & if so will choking
still be supported?
Any advice would be much appreciated.
Thanks
Richard
RE: [DTXpress] RHH-130
2005-01-19 by rdamon@mckinney-usa.com
Greetings Richard,
From the beginning, I never used the TP65 pad for the hihat, instead using a
PCY65S, which gave me both pad/rim voices and more movement. The RHH-130 pad
itself doesn't move and is fairly rigid. Only the center rod that is
attached to the standard hihat stand actually moves. I prefer the feel of
using the standard hihat stand, as oppose to the HH65 pedal, as you can
adjust the tension of the pedal and it just feels more natural.
You can use the PCY150S on inputs 2,6 or 7 on the Dtxpress II and III
modules and get three zones, bell/bow/edge, as well as, choking.
OGD
   _____
Sent: Wednesday, January 19, 2005 11:56 AM
To: DTXpress@yahoogroups.com
Subject: [DTXpress] RHH-130
technique issue)?
still be supported?
Thanks
Richard
The information transmitted herewith is sensitive information intended only
for use to the individual or entity to which it is addressed. If the reader
of this message is not the intended recipient, you are hereby notified that
any review, retransmission, dissemination, distribution, copying or other
use of, or taking of any action in reliance upon, this information is
strictly prohibited. If you have received this communication in error,
please contact the sender and delete the material from your computer.
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
Re: RHH-130
2005-01-19 by Keith
--- In DTXpress@yahoogroups.com, rdamon@m... wrote:
> Greetings Richard,
using a
OGD,
I have just bought the TP100 for a snare so had a shuffle round and am
using a PCY65 as a hihat and am finding it quite good.  For some
reason I like the TP65s as ride/crash/china cymbals.  With my TP65S
now as a ride I have a couple more rim sounds as well.  Who needs a
magic box to get more sounds?!
Keith.
RE: [DTXpress] Re: RHH-130
Keith,
Never thought of using the TP65S as a cymbal. Good place for it with the
addition of the TP100.
OGD
   _____
Sent: Wednesday, January 19, 2005 12:37 PM
Subject: [DTXpress] Re: RHH-130
> Greetings Richard,
using a
OGD,
Keith.
