Output level issue
2005-04-20 by Frank Northcutt
I purchased my dtxpress III last weekend. The only issue I have with it is the output level. I use it for home recording. The output runs from the controller to my BR-864, stereo in. I had to raise the trigger gains to max, and turn the pad volumes up high, and I still need the recorder input sensitivity and input level quite high to get a decent signal. The phone output on my DD-55 is pretty hot, so I tried that on the dtxIII, and it was better, but not like the '55. Has anyone else had issues with low output level? Any suggestions, other than adding a preamp? Thanks, Frank
