2006-03-02 by Chris . B.
Hi Peter,
Describing your music style helps a lot when deciding what
stix to use. Sounds like you would best off with a 7A stick size,
you could probably get away with a 5A as well, though that's
starting to get a bit on the heavy side of things.
Some folks may disagree, but I don't think it matters what type of
tip you use on e drums, however, I swear by nylon tips for all
rock/pop drumming applications.
When I was 16, (a very long time ago!) I was playing
hard rock / punk and used 5B's but as I've settled down and my style
has matured, I find lighter stix are much easier to use and am able
to still hit heavy without snapping them prematurely.
I'm a bit concerned to hear that your stix
only "lasted a little while", as you shouldn't be hitting e drums
that hard that you start breaking them!
Anyway, at the end of the day it comes down to personal choice.
I can only recommend light stix in your case.
I use: Pro Mark and Vic Firth 7A's, 5A's and American Jazz -
all are nylon tips.
These stix are made of Hickory and if looked after, will
last you a long time..........especially on e drums.
Let me know how you went,
Chris.B
--- In DTXpress@yahoogroups.com, "pcbye111" <pcbye@...> wrote:
> Greetings:
> I know this is a lame question, but I am in the process of
selecting
> some drum sticks. I am a keyboard player in general but acquired
a
> DTxpressIII SP and have little experience on drums, let a lone E-
> Drums.
> Any of you folks have suggestions / guidence on stick selection.
Way
> too many brands, sizes, tips, etc.
> I bought some cheap ones with plastic tips. They lasted a little
> while. Now I want something more in line with what others
generally
> use.
> My personal music style would be more 80's Synth Pop, but some of
> folks I practice with are moderately aggressive rockers. I also
need Show quoted textHide quoted text
> sticks for my DD55's that I use as MIDI controllers for synths and
> for percussion effects.
> Any and all suggestions welcome.
> Best regards;
> Peter B.
