RE: Spam:[DTXpress] Re: hihat again......
2006-09-27 by Damon, Rob
If it is still under warranty you may want to return it. If you are like me, I took mine apart the first week I got it just to see how it worked. There are photos in the archive section here that I took of the inside of the RHH. It works very similar to the HH65 pedal, except they just moved the rubber rocker with the ridges that make contact with the sensor strip up into the bottom of the RHH pad. They also added one more ridge and sensor section on the ribbon inside. If you open it up you can manually press down on the rubber rocker at each stage and see if you are getting any thing different. I noticed that with one of my older HH65's that the rubber rocker had stretched, thus was always in contact with the first sensor strip. Since the HH65 calibrates each time you turn on the module, it was getting a bad reading and did not give the full range of motion. Hence, this is why they tell you not to press down on the HH65 when you are turning on the module. There may just be something stray that broke off in shipment (this was a problem with the very first shipment, but most I believe were fixed at Yamaha's distribution center in Chicago prior to shipping to retail outlets.) OGD ________________________________
From: DTXpress@yahoogroups.com [mailto:DTXpress@yahoogroups.com] On Behalf Of Keith Sent: Wednesday, September 27, 2006 5:09 PM To: DTXpress@yahoogroups.com Subject: Spam:[DTXpress] Re: hihat again...... --- In DTXpress@yahoogroups.com <mailto:DTXpress%40yahoogroups.com> , Hans Meier <dronsb@...> wrote: > > Hello Keith, > > I`ve measured the resistance today and I have the same > values than you- but I`ll find it almost impossible to > get the readings between 150k and 350k! I cannot hit > and hold them even for a second, neither with my feet > nor with my hand! The only value in between that I`m > halfway capable of hitting an holding is the 350k, > next will be eternity. > Even stranger when you assume what the guy from > drumtec told me (7 resistors...)?! > I`ve also found another setting in the drumset overall > parameters that is named HH sensitivity, played around > with it but didn`t do much diference at all. Wolfgang, Unless someone else can shed any light on this problem, I would suggest maybe you have a faulty HH controller. I don't know how the RHH works, but the HH pedal progressively shorts out the resistors to give the final values (it actually consists of 150k, 10k, 47k & 150k resistors in series). Maybe you should return it as faulty? Keith. ____________ ______________________________________________________________________ The information transmitted herewith is sensitive information intended only for use to the individual or entity to which it is addressed. If the reader of this message is not the intended recipient, you are hereby notified that any review, retransmission, dissemination, distribution, copying or other use of, or taking of any action in reliance upon, this information is strictly prohibited. If you have received this communication in error, please contact the sender and delete the material from your computer. ______________________________________________________________________ This email has been scanned by the MessageLabs Email Security System. For more information please visit http://www.messagelabs.com/email ______________________________________________________________________
