Problem with FootCL
Problem with FootCL
2009-05-19 by fer2itm
Hi everyone!
Sorry my very little english.
My HH Pedal is not working, it open and close the HH but not produce footCl Sound, and not footCl trigger detected by the VOICE function.
Help me please, the DTXpress is new for me and i have not idea.
greetings!!!!
Re: Problem with FootCL
2009-05-20 by Keith
--- In DTXpress@yahoogroups.com, "fer2itm" <fer2itm@...> wrote:
> Hi everyone!
> greetings!!!!
You don't say which version of the DTXpress you have so I have assumed version 1.  Let me know if it is different as the manual pages will be different.
You should be able to get four sounds from the hihat, plus some sounds between open and closed.  You should get:
open - when you hit the pad and the pedal is not fully closed
close - when you hit the pad and the pad is fully closed
footCL - when you close the pedal
Splash - when you close the pedal and immediately open it.
Also, between "open" and "close" you should get a few other partially closed sounds when you hit the pad.  There are also rim sounds if you have a 2 zone pad for the hihat.
First, make sure you are using a stereo cable for the hihat pedal.  It is always worthwhile swapping it for another one just to make sure it isn't faulty.  I assume you have it plugged into input the HiHat Control input.
If the cable is ok, try a different pre-programmed trigger set and different pre-programmed kit to make sure it isn't your kit/trigger settings.
There is a hihat sensitivity setting - see page 5-3 of the "Reference Guide" (not the "Owners Manual").  I have mine set to 20 which is the default.  It is part of the kit settings.
There is also a hihat offset (HH Offs) and splash detect time (T) in the utility menu (see page 29 of the Reference Guide").  I have mine set to -10 & 45 respectively, although the default is -10 & 32.  The splash time can be tricky to get right, although it is mainly down to the technique of playing.
There is also a physical adjustment on the hihat pedal at the front - use a drum key.  It can help if you find you are having to press too hard to keep the hihat closed.
I hope this helps.
Keith.
Re: [DTXpress] Re: Problem with FootCL
2009-05-20 by Fernando Vargas
Thanks everyone!! specially Keith!
The problems is the hardware, the pedal is not working well, I give it to a qualified yamaha service and the diagnostic is the rubbers inside of pedal are damaged, so is a hardware problem.
Thanks and so much greetings!!!!
--- El mar 19-may-09, Keith escribió:
De:: Keith
Asunto: [DTXpress] Re: Problem with FootCL
A: DTXpress@yahoogroups.com
Fecha: martes 19 de mayo de 2009, 23:42
--- In DTXpress@yahoogroup s.com, "fer2itm" wrote:
> Hi everyone!
> greetings!!! !
I hope this helps.
Keith.
¡Obtén la mejor experiencia en la web!
Descarga gratis el nuevo Internet Explorer 8.br> http://downloads.yahoo.com/ieak8/?l=mx
2009-05-21 by Keith
Ahh, I didn't realise it was an old pedal.  I have seen a similar thing before, although not with the rubbers.  There is a PCB in the pedal with a plastic film above it with conductive areas on it.  This is separated from the PCB with a spacer.  The rubber pushes the film onto the PCB.  Someone had a pedal which wasn't working and the plastic film was permanently deformed so it always touched the PCB.  I pealed off the plastic film & put it back again and that fixed it.  I am not sure how long it would have lasted, but it would have been useful as a spare pedal.
I'm glad you have found the problem.  I assume Yamaha can just replace the broken part?
Keith.
