Subject: RE: [DTXpress] Re: DYXpress (orange) Everything except bass drum plays through the headphones.
To: DTXpress@yahoogroups.com
Date: Tuesday, June 18, 2013, 9:21 AM
To use the input jack on the bass drum pad (KP-65) to add a pad downstream of the bass drum pad requires a stereo cable between the module and the bass drum pad and then a mono cable from the bass drum pad to the downstream pad. If a mono cable is used between the module and the bass drum pad the input jack on the bass pad is not functional. The sound you get when plugging the jack into/out of the input is just a shorting most likely. Rob From: DTXpress@yahoogroups.com [mailto:DTXpress@yahoogroups.com] On Behalf Of keith1200rs
Sent: Tuesday, June 18, 2013 12:04 PM
Subject: [DTXpress] Re: DYXpress (orange) Everything except bass drum plays through the headphones. Jeff,
I am glad its sorted, even if I didn't manage to solve it!
Keith
