Dual triggers on DTXpress
2003-01-19 by webleo <webleo@yahoo.com>
I am attempting to use the same trigger for 2 pads (same sound for 2
pads). When I attempted to split the snare (trigger 2) to two pads
with a mono Y-splitter.
The problem is, the volume of both pads decreases with one being
barely audible. I was wondering whether I am doing something wrong.
What alternatives do I have? Would I be able to split into the 2
pads with both sounding identical?
Re: Dual triggers on DTXpress
2003-01-19 by liberatusvirus <liberatusvirus@yahoo.com>
I've never done that, but when you split a signal, you often reduce
its volume unless the current is very high and the resistance/
impedance low. The same phenomenon can happen when you split the
signal from your receiver to your speakers in your home stereo. All
that I can think of is raising the snare's gain and volume settings
as well as adjusting the song knob on the front of the module, which
further controls the snare's volume when you're in the "live" mode.
But I'm not optimistic.
Ed
--- In DTXpress@yahoogroups.com, "webleo <webleo@y...>"
2
wrong.
Sorry, my first attempt completely miscontrued your situation.
Please forget it. I can't see why you wouldn't be able to run two
identical pads into trigger 2 with a splitter. But using a single
stereo feed to the module's input from the two mono leads may result
in just what you're describing. Trigger 2 is a "stereo" input, but
it is not stereo in the sense that it accepts separate left and
right signals; "stereo" in e-drum parlance refers to a pad with a
piezo trigger for the body and what's called a "switch" for the rim.
You can't split this type of stereo into two mono signals.
Essentially, any "stereo" input to trigger 2 will be expecting to
read a piezo and a switch, but your situation is delivering two
distinct monos, thereby severely disrupting the input's normal
operation. If you use a splitter with all mono sections, you should
be able to get the piezo sound when you strike either pad. If you
use one with all stereo sections, you might just be able to get both
rim and body on both pads.
2
wrong.
