pm-16 program change
2003-04-03 by hairytrigger
Well, it only 'sort of works.' In the Pm-16, you can set the 'Program Change number.But it seems to have no effect. There is a Chart that shows the relationship between the program number received, and which patch it will select. There is no correspondence. For example, my patch 31 is selected when program number 17 is received. So if i SELECT kIT 17 ON THE dTX, PATCH 31 IS SELECTED ON THE pm-16. That is almost useless. I never use that kit. So i need to figure out why it lets you change the program # if it has no effect!! But, by using that table, if I save my DTX kits to numbers that are available on the PM-16, It will work. That means moving kits around in the DTX, and then just using the patch locations on the PM-16 that are selected.... Scott
