dtx + midi + os x + cubase + midiman = ????
2003-08-16 by pulsetodd
The problem of course with recording electronic drumkits as an analogue sig= nal is they send a stereo out for the combined kit. This makes it difficult to re= mix different voices (kick, snare etc) and pull a decent mix after the final takes. The = solution in theory should be to record in midi using your electronic drumkit... Now if I can only work out how to set it up. This is the recipe so far... 1. Buy an iMac with the latest version of OS-X, a USB Midiman Interface, lo= ad the drivers 2. Dust off your DTXPRESS set it up, connect it into the Midiman/Midisport = box per the instructions 3. Check out cubase.net for the instructions you need to set up your Midisp= ort 2x2 for OS X (the one's they don't tell you about). Follow these, learn a few = things. 4. Check your configuration via the dtxpressions.com website. 5. Double check everthing. 6. Scratch your head and wonder why you are not getting a signal into your = Midiman or into Cubase. 7. Post at the cubase & dtxpress forums for advice / wisdom. Any clues? Anyone using their kit with OS X or Cubase? ------------------ yup, uh huh, hmmm, uh huh, uh huh, sorry, you lost me, can you run that by me again?
