TP60 drum pad replacement
2003-12-29 by Diane
I have a DTXpress drumkit with a TP60 pad that stopped working
responsively (it triggers lightly when hit hard, not at all when hit
softly), and am looking for either a way to repair it or a
replacement.  Can anyone offer any suggestions?
Thanks
Re: TP60 drum pad replacement
2003-12-29 by emf
hit
Hi Diane,
The cause of the signal interruption could be any number of things.
To start with the simplest, try another cable. Then you could try a
little WD40 inside the jack and/or on the plug. If that doesn't work,
you could re-solder the connections on the circuit board and, failing
that strategy, buy another inexpensive piezo at Radio Shack (someone
here has the part number) or elsewhere. Such are the cost-effective
solutions. If buying another drum is unavoidable, Drumbalaya.com or
ebay are options for a used TP60/TP60S or TP80/TP80S, which are also
compatible with your system. Assuming that your current snare is not
the offending pad, and is a TP60/60S, too, you could move it to the
broken TP60's position and buy a TP65S to replace it. You won't get
the second rim sound (assuming that you have the DTXpressI module),
but it will have the advantage of being new and presumably trouble-
free for a long time. If the offending TP60 is your snare, another
rubber pad with the "S" designation would be a good upgrade, anyway.
A Pintech SE rubber pad is possible, too, as well as a mesh option
(though the latter has complications that we would have to pursue
more).
Ed
