Using internal sounds in tandem with ext. midi module
2004-01-11 by entropy7602
Hello all, I just got my dtxpress II a few weeks ago and have run into a problem. I am trying to use the internal dtxpress drum sounds in tandem with samples triggered from my Kurzweil K2000. In voice edit mode I have set the TOM3 trigger to midi channel 1, which is what my K2000 is set to receive on. Striking TOM3 will trigger the sound on the K2000, but it also triggers a piano sound from the dtxpress GM voice list. if I set the voice select to "no assign" then no midi event is generated at all. I know I can totally disable the internal tone generator, but I still want to use the internal drum sounds. I tried a few vague searches in the archive but didn't come up with anything. Any thoughts? Thanks
