New Database "Favorite Voice Settings"
2004-01-24 by oldguydrummer
To All: I have setup a simple Database in our database section for storing members favorite voice settings. As a sample, I used Adams recent posting of his HiHat settings, to get it rolling. I was going to set up a spreadsheet in Excel, but since not everybody has Excel, not everyone could access it. (I am still willing to setup one, if there is enough interest in it.) The nice thing about doing it here is that any member can access and print it out from here, without using any special software. There are four fields: Contributor Pad Type Settings Comments You can put your yahoo user name under Contributor or just use "Anon". "Pad Type" would be: Bass, Snare, Tom, Ride Cymbal, Crash Cymbal, Splash Cymbal, HiHat, etc. When you add something, try to be consistant with this field, so that when it is sorted, all the "Snare" voices will sort together. IF it is something else other than a standard pad, you could use "Misc - Cowbell" or "Misc - Wood Block" for example, and if something similar already exists in the list, try to name it using the same convention, again, so they will sort together. "Settings" can be as much or as little as needed to get the idea across. If you have just tweaked a few settings, then in the comments section you can just say "All other settings remain the same." Anybody can add to the database. As I get the time, I will go back through the posts from this group, where members have already shared their settings and add it to the database. Keep in mind, that if there is anything else, that you would like to keep track of that would work in this format, we can set it up. By having a moderator set it up, we can set it so that it can't be deleted accidentally by a member. OGD
