Modules - Fit the Second
2004-03-18 by moosetication
More on module user interfaces I want a non-embarassing, non-text-based, zero-twiddly-button user interface that does what I expect, when I expect it. From a library of images on a palette, I want to drag and drop little pictures representing my kit onto a canvas into a configuration approximating what I sit behind every day. I don't want them to be photorealistic, or to be able to resize them, change colours, spin them, or any other damn thing. I just want them to look reasonably representative, and to place them on a canvas so I recognise what I'm dealing with. I want to have as many pads as I like, name them anything I like, put them anywhere I please. I want to save those canvases of pads as "kits" - as many as I like, called whatever I want. When I have a "kit", I want to be able to select one of those pads (with a touch screen that's rugged enough to stand me using the bead of a drumstick) and change the things I'm interested in. The hole on the back it's attached to. Its name. Its sounds. Its behaviour when hit. All the things I can change, I want to have a sensible name so I understand it when I see it, and even then I want online help that explains what "triggers" are and why I should give a flying crap about "rejection". I only want to see complicated technical jargon like MIDI note numbers when I ask to. When I'm dealing in configuration of module settings, rather than pads (volumes, output channels, and the like) I want to have a picture of the module to deal with, just like I have a picture of the kit. If I'm connecting pads to output channels, I want to drag a little wire from the pad to the output channel on the module graphic, not scroll through menus of stupid options. When I'm done, I don't want to have press "Save" eight times while standing on my head to make sure the bloody thing doesn't get lost when I change kits or power off the module. If I select another pad, I want it to assume I'm done, save the previous pad and open the new one for modification. I want it to save the kit continually. And I want multiple levels of undo and redo. When I play the kit, I want what I hit to be indicated on the graphic. And as for recording and playing songs - well. I could go on for hours. Why is it so BLOODY HARD?
