Rolland Mesh Head with DTXpress III
2004-03-21 by wzk283
Does anybody know if the Rolland PD-80R Will work with the DTXpress III in the snare input
2004-03-21 by emf
--- In DTXpress@yahoogroups.com, "wzk283" <mark_davies@n...> wrote: > Does anybody know if the Rolland PD-80R Will work with the DTXpress > III in the snare input Hi Mark, Welcome. In principle, it "works," although you'd have to split the rim trigger to input 9/10. That said, however, we've had varying reports about how well it works. Some people are satisfied with the head's response, and others complain that Yamaha's lack of an input- sensitivity adjustment severely limits dynamic range on the softer end. The rim apparently does not trigger loudly enough, possibly because of the rubber trim or the position of the piezo. The head response could be helped with the insertion of a 250k pot, but the rim may not be curable. The Hart option also might have problems. If you have your heart set on a mesh snare, why not consider a Pintech ConcertCast rather than the Roland? You'll save a lot of money, and you'll get a quality piece of equipment, not to mention excellent customer support. The Pintech rim works fine through the Yamaha DTXP, and if you find the sensitivity too hot, you can always insert the pot. Many people, however, are content with it just as it is. Ed
Thanks in will look into "Pintech ConcertCast" Look like a 10" Snare will be around I have not yet purchased my DTXPress III (not in UK for another few weeks) Would you recommend buying just the DTXPRESS III Module and all "Pintech" meshheads or would the Yamaha rubber pads e fine as I'm a total begineer.
2004-03-21 by emf
--- In DTXpress@yahoogroups.com, "wzk283" <mark_davies@n...> wrote: > Thanks in will look into "Pintech ConcertCast" Look like a 10" Snare > will be around > > I have not yet purchased my DTXPress III (not in UK for another few > weeks) Would you recommend buying just the DTXPRESS III Module and > all "Pintech" meshheads or would the Yamaha rubber pads e fine as I'm > a total begineer. Mark, I lean toward keeping the original kit intact. The module was made primarily for the rubber pads that come with it. Until you learn how to program, and what kinds of effects are possible with different settings, the attempt to integrate a mesh configuration with the DTXpress module could be a frustrating experience, seriously detracting from your ability to enjoy and learn. Follow the usual curve. Set the pads up, get acquainted with the factory kits, create your own, and gradually get a sense of what the instrument can do. Eventually, when you get the hang of it, and know enough about what you have and what alternatives are available, you can gradually add or replace as you see fit. I'm assuming that by "total beginner," you mean no previous experience on acoustic drums. If we knew a little bit more about your background and intentions (I realize that you're not proposing marriage to my daughter), various people could make recommendations about lessons, acoustic drums, etc. that may be relevant to your situation. At any rate, it's great to have you with us. Ed
2004-03-22 by wzk283
Thanks Nice to be on board > I lean toward keeping the original kit intact. The module was made > primarily for the rubber pads that come with it. Until you learn how > to program, and what kinds of effects are possible with different > settings, the attempt to integrate a mesh configuration with the > DTXpress module could be a frustrating experience, seriously > detracting from your ability to enjoy and learn. Follow the usual > curve. Set the pads up, get acquainted with the factory kits, create > your own, and gradually get a sense of what the instrument can do. > Eventually, when you get the hang of it, and know enough about what > you have and what alternatives are available, you can gradually add > or replace as you see fit. I'm assuming that by "total beginner," you > mean no previous experience on acoustic drums. If we knew a little > bit more about your background and intentions (I realize that you're > not proposing marriage to my daughter), various people could make > recommendations about lessons, acoustic drums, etc. that may be > relevant to your situation. At any rate, it's great to have you with
> us. > > Ed
