amplification
2004-03-21 by johnnyeckstein2004
hey fellow drummers. can anyone tell me why the cymbals come out too hot when running DTXpress in an amplifier as opposed to headphones? Is there a different setting or is there a special amp for this set? thanks for any help. John E in San Francisco.
2004-03-21 by emf
--- In DTXpress@yahoogroups.com, "johnnyeckstein2004" <johnnyeckstein2004@y...> wrote: > hey fellow drummers. can anyone tell me why the cymbals come out too > hot when running DTXpress in an amplifier as opposed to headphones? > Is there a different setting or is there a special amp for this set? > thanks for any help. Hi John, From time to time someone will complain that their edrums do not sound the same through headphones and amplification. Some of the difference is due to variations in an amp's frequency response. Some amps emphasize bass, some the midrange, others the treble, and others etc. The sonic environment of a room can also add or substract considerably from the frequency response curve. A kit will also change its sound from stage to audience, side to side, etc. Phones are usually pretty flat, with fewer variables to color the sound, making them a better bet for how the kit "actually" sounds. But if your phones have deficiencies that your amp doesn't have, you could be surprised hearing yourself live. The obvious answer in your case is to back off on the volume of the cymbals and change the frequency cutoff, maybe even use outboard eq if brightness is a problem out front. There's no guarantee, however, that the settings that you come up with for one place will be exactly right in another. I'd like to hear the sonic balance of the satellite/sub combination that Yamaha recently began selling as a dedicated complement to the DTXpress/DTXtreme kits (MDR-50 and 100). No one has volunteered a report here as yet. Ed
2004-03-22 by Creighton Higgins
johnnyeckstein2004 wrote: >hey fellow drummers. can anyone tell me why the cymbals come out too >hot when running DTXpress in an amplifier as opposed to headphones? >Is there a different setting or is there a special amp for this set? >thanks for any help. > >John E in San Francisco. > > > > > >Community email addresses: > Post message: DTXpress@yahoogroups.com > Subscribe: DTXpress-subscribe@yahoogroups.com > Unsubscribe: DTXpress-unsubscribe@yahoogroups.com > List owner: DTXpress-owner@yahoogroups.com > >Shortcut URL to this page: > http://groups.yahoo.com/group/DTXpress > >Alternate DTXpress site: > http://www.dtxpressions.com >Yahoo! Groups Links > > > > > >. > > > Hey John I have found that treble setings both on the amp and in the utiity menu make a HUGE difference in cymbal volume. The PA I am using for live work seems to adjust treble starting in what i think of as mid-range and a small adjustment there makes a very large difference in kit balance. This is a very big subjective difference compared to my 'phones. At first I tried to fix this using the gain settings for each cymbal pad- almost no difference. I have also noted that the high frequencies "beam" considerably so it is important to have a monitor facing me as close to ear level as possible. Otherwise I am sending a trble-heavy signal out to the crowd. Good luck. Creighton
