--- In DTXpress@yahoogroups.com, "Just ask.." <djames_wa@y...> wrote:
> Greetings everyone,
> I have a new-used Dtexpress II with my snare only firing the snare
> sound. The rims are not firing separate sounds.
> The first thing I did when I got the kit home was too reset the
> factory presets, still no sounds out of all three zones from my
> TP65s. Ohhh and it's plugged into input #2 with a stereo cord.
> Am I missing something? Is there a setting I can go too to fix this
> or is this trigger toast??
> Thanks in advance,
> D~man.
D~man,
Here are a few things you can try (note that the page numbers
referred to below are the page numbers of the manual that comes with
the kit and not the downloadable PDF manuals from Yamaha's website):
Try using a different stereo cord first. (Also, make sure you are
using the TP65S and not the TP65. The TP65S has grooves around the
top edge, the TP65 does not.)
Next up is check to see if the trigger setup for input no. 2 is set
to a pad type "TP65-1" and not "TP65-2".(Page 36 of manual)
Next go into voice edit mode for that pad and verify that a voice is
assigned to the "snare" , to "snrR1" and to "snrR2". Make sure the
volume is setup on all three voices. (Page 40 of the manual)
If it still doesn't work, connect the pad to trigger inputs 6 or 7.
You will need to temporarily change the trigger type and the voice
assignments, so copy the existing settings down before you change
them.
If it still doesn't work, then if maybe a bad pad.
Good Luck. Let us know what happens.
OGD
