DTXpress Compatibility
2004-04-14 by zmonkoffunk
I have a dtxpress, original version, that I use to practice with
at home. I'm starting a new jazz/fusion project, and ordered a 4
channel headphone amp/mixer for practicing with my new bass player.
The mixer has dual 1/4" lines in for stereo. Does that mean I run 2
mono cables out of the dtx into the mixer? Just want to make sure.
    Also, I was looking around at some accessories. Can I use the
new 3 zone snare pad with my DTXpress 1? Can I get one of the 3 zone
cymbal pads also? Can I use one of the cymbal bell attachments? If
so, how do the cymbal bell attachments work? Do they plug into the
cymbal first, then run into the brain?
   I've had this kit for awile, and it's main use has always been
for personal practice. I've always used my acoustic for live playing
and band practice. I just need a little help to make the jump to
accoustic/electric hybrid, or electric.
   Thanks in advance for your help.
   Eric
Re: DTXpress Compatibility
2004-04-14 by emf
--- In DTXpress@yahoogroups.com, "zmonkoffunk" <zmonkoffunk@y...>
with
zone
playing
Hi Eric,
Welcome and good luck on the new project. You can run two mono cables
from the back of the module into the mixer or run a splitter (stereo
to two monos) from the jack in the front. You can use the three-sound
snare and cymbal with your module, but you'll only get two of the
sounds. You'd need the second version of the DTXpress module to get
the full complement. The PCY10 cymbal bell is an altogether separate
component, requiring its own input (presumably either 9 or 10). It
can stand alone or mount atop another cymbal. Unless you already have
one lined up, you might contact Ed Morin at Drumbalaya.com about
getting one. I haven't seen too many.
Ed
2004-04-15 by wb7ubd
> with
player.
run 2
sure.
> zone
If
been
> playing
> Hi Eric,
cables
(stereo
sound
get
separate
have
> Ed
We have exactly ONE PCY-10 left and then that's it.  Yamaha has
discontinued them.  :-(
Ed
