Digital B&W to Traditional B&W
2010-07-05 by Alan
Hello,
I know this will sound strange but it is out of artistic curiosity I would like to try this. Is there any method of getting a scanned in B&W negative image that has been Photo shopped back into some format I could put in an enlarger and print using traditional wet printing? I have a Beseler 23CII enlarger and B&W darkroon set up.
Thanks
Alan
Re: [Digital BW] Digital B&W to Traditional B&W
2010-07-05 by jvee
David,
There are several ways to do this, including using a film recorder to make a negative.  I find that printing the digital image at, say, 11" X 14" and then using (very carefully) an excellent copy camera setup will do best.  I have a bit of an advantage in that I have available a 4" x 5" and 11" X 14" sheet film view cameras with finest process lenses very useful for this.  In fact the larger camera makes a great way to make contact prints for the alternate processes as well as silver.    J Vee    www.jveegraphics.com   jvee.com
On Jul 5, 2010, at 10:12 AM, Alan wrote:
> Hello,
> Thanks
> Alan
Re: Digital B&W to Traditional B&W
2010-07-05 by martin_wesley1
Alan,
What you are looking for is a "film recorder" that transfers digital files/images onto film. Been around for quite awhile.
I gave it a try back in the late  90's. Scanned a neg, worked on it in Photoshop, had the file output to 35mm file by a service bureau and then I printed on silver gelatin in my darkroom. The results were very poor.
Too many steps. The image is being degraded with each change of medium and in my case did not survive. If I had owned the film recorder and been able to do some calibration the results would have been better but I don't believe that they would have been acceptable.
But the tech may have improved in the last decade. If you find something outthere let us know.
Martin Wesley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Alan" <alanj.martin@...> wrote:
> Hello,
> Thanks
> Alan
2010-07-05 by Mark Nelson
Sure, with digital negatives made on your inkjet printer that you then
contact print. Works incredibly well !
Mark Nelson
www.PrecisionDigitalNegatives.com
PDNPRint Forum @ Yahoo Groups
www.MarkINelsonPhoto.com
sent from my iPhonetypeDeviceThingy
On Jul 5, 2010, at 10:12 AM, "Alan" <alanj.martin@...> wrote:
> Hello,
> Thanks
> Alan
2010-07-05 by Alan
Well I do have a copy stand and an 6x9 medium format camera along with the negative carrier I would need for the enlarger, not really what I had in mind though. I was hoping maybe someone had invented some material you could stick into a printer, like printing a transparency only much better detail. I have an Epson R1900  printer.
Alan
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, jvee <j_vee@...> wrote:
> David,
> > Hello,
> > Thanks
> > Alan
2010-07-05 by Alan
WoW, never heard of this, can you give me more information, source, experience and such?
Alan
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Nelson <Ender100@...> wrote:
> Mark Nelson
> > Hello,
> > Thanks
> > Alan
RE: [Digital BW] Digital B&W to Traditional B&W
2010-07-05 by Phil Radlick
Dan Burkholder's book is very helpful on this topic.   "Making Digital
Negatives for Contact Printing " is the title.
Best, Phil
Alan
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , Mark Nelson
> > Hello,
> > Thanks
> > Alan
2010-07-05 by Alan
Ok, I see, you need to print to a transparency sheet at full 8x10 and then use your contact print setup. I would like to make a 35MM or even a 6x9 size image so I can use the features of my enlarger (filters, F stop setting and such)I bet at that size this method would not yield a decent negative? Any one tried it?
Alan
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Phil Radlick" <pradlick@...> wrote:
> Best, Phil
> Alan
> > On Jul 5, 2010, at 10:12 AM, "Alan" <alanj.martin@> wrote:
> > > Hello,
> > > Thanks
> > > Alan
2010-07-05 by Ender100@aol.com
In addition to Dan Burkholder's fine book, I have a book and system for doing this.  See:  www.PrecisionDigitalNegatives.com
I personally use the PDN system with my own work in Platinum/Palladium and Photopolymer Gravure.  I teach a lot of workshops around the country and have done workshops with alt processes such as Gelatin Silver, POP paper, Kallitypes, Cyanotype and others.
It's a great way to make hand made prints.  Lots of work is being done this way.
Mark Nelson
Sent: Mon, Jul 5, 2010 12:56 pm
Subject: Re: [Digital BW] Digital B&W to Traditional B&W
Alan
> Mark Nelson
> > Hello,
> > Thanks
> > Alan
2010-07-05 by C D Tobie
Yes, inkjet resolution is not sufficient to print 35mm negs with
sufficient resolution, but if you put the neg at the other end of the
process (in contact with the paper), then it can work well.
C. David Tobie
Global Product Technology Manager
Digital Imaging & Home Theater
CDTobie@...
Datacolor
www.datacolor.com/Spyder3
2010-07-05 by Mark Savoia
It will look like crap. The dot pattern of the inkjet process will be enlarged. You really can only do the contact process at size of neg you make. Unless you are looking for a certain look.
The film recorder or LVT output is only real choice for a "conventional" silver based (no large dots) neg from a digital file for use in enlarging.
Nobody has seemed to ask you this question "why do you want a neg and not just print the digital file directly via inkjet or light-jet"?
Mark
http://www.stillrivereditions.com
The answer I have always gotten when I ask this is "because I want to
still play around with my enlarger and chemical process". Its not an
argument that  moves me personally, but it seems to be a common
feeling among the "chemicals on my hands" crowd. However, their
enthusiasm is somewhat dampened when they find its a contact-only
process, since that eliminates much of the enlarger functionality.
C. David Tobie
CDTobie@...
Datacolor
There are still many people who value hand made prints and love the beautiful prints that result from the the many alternative processes or historic processes.  There is nothing wrong with either an inkjet print or a Platinum Palladium print—they are apples and oranges and each should be judged on its own merit.  Many of the great fine art photographers prefer the alternative processes in conjunction with digital negatives.  Contact printing does have its advantages.
Mark Nelson
www.precisiondigitalnegatives.com
Sent: Mon, Jul 5, 2010 1:42 pm
C. David Tobie
CDTobie@...
Datacolor
2010-07-05 by Alan
Well I see someone already answered your question for me! But if you read the first sentence of my O.P.
 " I know this will sound strange but it is out of artistic curiosity I would like to try this."
So you see I knew someone might wonder the same thing as you. There are a lot of artistic things that can be done both during and After the print has been made, things like different kinds of bleaches (farmers reducer for one) Different kinds of toning, hand tinting, different papers, I could go one.  So I guess the next question is why do I want to bother with Digital Black and White? Same reasons.
Thanks for you reply!
Alan
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia <mark@...> wrote:
> Mark
2010-07-05 by Alan
What? I guess all us Black and White folks look alike....
Sorry if my artistic ambitions dont "personally move you" (your words).
Thanks for taking the time to reply though.
Alan
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, C D Tobie <CDTobie@...> wrote:
> C. David Tobie
> CDTobie@...
> Datacolor
2010-07-05 by ann clancy
i have used Mark's system for making digital negatives and then contacted to silver gelation paper.
they are lovely and why , because it is just another tool. It is very nice for alternative process as one doesn't have to run around with a LF camera, film holders, etc.
ann
To: "DigitalBlackandWhiteThePrint@yahoogroups.com" <DigitalBlackandWhiteThePrint@yahoogroups.com>
Date: Monday, July 5, 2010, 1:43 PM
Mark Nelson
On Jul 5, 2010, at 10:12 AM, "Alan" <alanj.martin@verizon.net> wrote:
> Hello,
> Thanks
> Alan
On Jul 5, 2010, at 3:09 PM, Alan wrote:
> Well I see someone already answered your question for me.
Not for you, I figured you'd do that for yourself; for a couple dozen
others who I've asked the similar question to. It always comes down to
wanting one or another feature of chemical photography in the mix;
some classic method, or some classic look.
C. David Tobie
CDTobie@...
Datacolor
> words).
Wouldn't expect them to. What I would hope is that your results
personally move me. And I could wish the same for my results and
you... even if inkjet isn't your preferred output medium as it is mine.
C. David Tobie
CDTobie@...
Datacolor
2010-07-05 by john
Mark Nelson,
How large is it possible to do these inkjet negs for contact printing to silver and platinum? I really want to do some 22"x28" size.
I remember years ago the Pictorico Film in the roll sizes had a lot of pin holes that were impossible to deal with. Has the film stock improved recently?
john
> C. David Tobie
> CDTobie@...
> Datacolor
John,
I use roll stock all the time with no problem.  Mitsubishi makes the
film now.  You should be fine.
Mark Nelson
On Jul 5, 2010, at 6:08 PM, "john" <deanwork2003@yahoo.com> wrote:
> Mark Nelson,
> size.
> improved recently?
> john
> dozen
> down to
> > C. David Tobie
> > CDTobie@...
> > Datacolor
2010-07-06 by Mantinieri
Hello Alan,
  there are a couple of thinks that I am missing in this story:
1) what's wrong with using your enlarger to contact print digital negatives? I have never seen the results, but, in principle, it should be better than enlarging from 35mm film as you are skipping one step in the process (the enlargement through an extra lens). The flexibility of developing the paper with the process you prefer is preserved anyhow;
2) if you insist with enlarging from a 35mm film, why dont you get a film camera from e-bay and shot cheap film from freestyle? Then, you can use the frame with your enlarger or scan it. I have seen Nikon F90x won for 25$, cheaper than Pictorico paper. If yo have a wet darkroom for developing paper, developing film would be a breeze.
Ciao,
  Mantinieri
http://www.mantinieri.com
> Hello,
> Thanks
> Alan
2010-07-06 by Alan
I have a Nikon N90S (same as the F) A Ventura Deluxe 66, that is a medium format 6x6 folding camera that has been restored , including brand new baffle and an assortment of Pentax K1000's. I use these exclusively for B&W using mostly Kodak TMAX100 film. I usually develop the negatives my self using TMAX developer chemicals. I print on mostly Ilford paper, but I do like to experiment with others. I have a complete dark room setup built around a Beseler 23CII XL enlarger. So I am all set on that end!
I am definitely going to give the contact idea a try. I do make contact prints of my negatives before printing so i know how to do it for that application.
I wanted to go all the way back to the negative stage so i could use the various filters, better control the light source and such, maybe this is not a good idea, Im just looking for new ways to make artistic prints.
You seem to be asking why i dont just skip the digital part all together and do it all in my darkroom? I refer you to the first sentence of my OP.
"I know this will sound strange but it is out of artistic curiosity I would like to try this."
Thanks!
Alan
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mantinieri" <mantinieri@...> wrote:
> Hello Alan,
> Ciao,
>   Mantinieri
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Alan" <alanj.martin@> wrote:
> > Hello,
> > Thanks
> > Alan
2010-07-06 by tboleyyh
seems like the perfect solution for you John-
http://www.robgalbraith.com/bins/content_page.asp?cid=7-10053-10768
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "john" <deanwork2003@...> wrote:
> Mark Nelson,
> john
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, C D Tobie <CDTobie@> wrote:
> > C. David Tobie
> > CDTobie@
> > Datacolor
2010-07-07 by Clayton Price
Here's what I used to do back in the '90's:  Scanned black & white
( color transparencies, too), did the digital retouching/ altering/
fixing, then
had them output usually as 4X5 film negatives. Photos that were
filled with scratches, and needing contrast/ density adjustments,
could be fixed and printed
in silver -  corrected,  alternative processes, or whatever
experimental things one would like to try.
There are several labs in the NY/Boston area that still do this, and
I'd guess a number of others around the country as well.
Hope this helps.
Clay Price
Tyler
 > Mark Nelson,
 > john
dozen
down to
 > > some classic method, or some classic look.>>>>
Re: [Digital BW] Re: Digital B&W to Traditional B&W
2010-07-07 by John Forney
dr5.com still provides this (film recording) service
Sent: Wed, July 7, 2010 6:57:46 AM
Subject: [Digital BW] Re: Digital B&W to Traditional B&W
fixing, then
Hope this helps.
Clay Price
Tyler
> Mark Nelson,
> john
dozen
down to
2010-07-07 by meeshieck
Hi guys,
I've been following this subject as the whole idea has great appeal for me, god knows why...
anyway, can you please tell me what substrate would one use to print the digital neg?
thanks,
m.
2010-07-07 by ann clancy
pictorio white film
Date: Wednesday, July 7, 2010, 12:35 PM
Hi guys,
thanks,
m.
2010-07-07 by C D Tobie
> the digital neg?
I don't think its possible to explain each step in sufficient detail
on a list. You are probably best off starting from the book already
mentioned.
C. David Tobie
CDTobie@...
Datacolor
RE: [Digital BW] Re: Digital B&W to Traditional B&W
2010-07-08 by E.Neilsen
Even the clear works fine as the white really slows the exposure quite a
bit. On some exposures , I've used a Rosco gel on my contact glass to add a
touch of diffusion.
Eric Neilsen
Eric Neilsen Photography
4101 Commerce Street, Suite 9
Dallas, TX 75226
www.ericneilsenphotography.com
skype me with ejprinter
www.ericneilsenphotography.com/forum1
Let's Talk Photography
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of ann
clancy
Sent: Wednesday, July 07, 2010 11:47 AM
Subject: Re: [Digital BW] Re: Digital B&W to Traditional B&W
pictorio white film
--- On Wed, 7/7/10, meeshieck <michal@...
<mailto:michal%40bookandart.pl> > wrote:
From: meeshieck <michal@... <mailto:michal%40bookandart.pl> >
Hi guys,
god knows why...
digital neg?
thanks,
m.
2010-07-08 by john
Hey Eric,
How is the tonal linearity of this film when contacting on silver paper? You do any of that?
john
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "E.Neilsen" <e.neilsen2@...> wrote:
> touch of diffusion.
> Eric Neilsen
> Dallas, TX 75226
>   _____
> clancy
> pictorio white film
> Hi guys,
> god knows why...
> digital neg?
> thanks,
> m.
John, I decided a while back to just see how things would work. I grabbed a
file that was being prepared for platinum printing. I use a look like pyro
for my negs; the yellow brown pyro not green pyro. I also learned a while
back that we can waste a life time plotting and testing so, feeling it was
right I took some  Ilford MG IV and made some prints. Also some graded paper
from Cachet that was still kicking around my darkroom. These were shown at
several photo events, PPE , WPPI in Las Vegas. I never ran complete test,
because to be quite honest, I don't beat myself silly with silver gelatin
density tests. They looked great. I had no trouble printing them.
It has been very consistent, negs that work well for platinum, with my
colorized curve, work well for my silver gelatin with very little fuss.
Eric Neilsen
Dallas, TX 75226
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of john
Sent: Wednesday, July 07, 2010 8:10 PM
Hey Eric,
do any of that?
john
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "E.Neilsen"
a
> touch of diffusion.
> Eric Neilsen
> Dallas, TX 75226
> _____
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> ] On Behalf Of ann
> clancy
> pictorio white film
> Hi guys,
me,
> god knows why...
> digital neg?
> thanks,
> m.
2010-07-08 by Ender100@aol.com
I like the Pictorico Ultra OHP film.
Sent: Wed, Jul 7, 2010 7:11 pm
Subject: RE: [Digital BW] Re: Digital B&W to Traditional B&W
touch of diffusion.
Eric Neilsen
Dallas, TX 75226
_____
clancy
pictorio white film
<mailto:michal%40bookandart.pl>; > wrote:
From: meeshieck <michal@... <mailto:michal%40bookandart.pl>; >
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>;
Hi guys,
god knows why...
digital neg?
thanks,
m.
