RE: 1400 Problems
RE: 1400 Problems
2010-07-10 by nospam
I was not able to find any cure for the pizza wheels other than removing
them. Not an easy job. I first removed all the carriages that hold the
wheels and then I got absolutely terrible marks on the paper. So I look at
the positions of the marks on the page and noticed that it seems to be the
individual wheels that cause the problem. If you remove the carriages and
press on the wheels you will see that the single wheels have tighter
springs. These are the ones that left marks on my prints. I pulled the
single wheels out of the carriages and left the double wheels. Problem went
away.
Keep in mind that removing the carriages is easy but replacing them is quite
tricky. I had to construct a special tool to help guide the carriages back
into place. I was not able to find a way to simply remove the covers and get
to the wheels like I could on my 1200. The mechanism for the CD tray makes
the whole thing more complicated.
>First, though, I'd like to figure out how to get rid of pizzawheel
>marks. Has anybody succeeded in doing so? Even when using a relatively
>thin medium like Epson's Ultra Premium Photo Paper Glossy I get
>pizzawheels in the denser areas...
Scott
www.scotthendershot.com
Re: [Digital BW] RE: 1400 Problems
2010-07-10 by mike-theprint@waspfactory.org
> them.
You know, I was just looking at your post on this problem from February,
and wondering how it turned out.
So there was no way to slow down printing to give the ink more time to
dry? Like you I have a pretty significant investment in inks (UT14 in
this case), so I don't really want to switch to find a faster-drying
inkset.
I tried shimming the wheels up, but the result was that the bottom few
inches of the print were very poorly defined as the paper fed
incorrectly, and this printer's too small to allow a two-inch margin.
> I first removed all the carriages that hold the wheels and then I got
> absolutely terrible marks on the paper. So I look at the positions of
> the marks on the page and noticed that it seems to be the individual
Indeed, I'm not seeing any double-wheel marks on the prints where it's
an issue. So I'll keep the wheelectomy in mind...
  | Mike Acar |                                | mike at waspfactory dot org |
