RC inkjet paper without fluorescents?
2010-09-30 by Ernst Dinkla
I have yet to see an RC inkjet paper, gloss, satin, pearl, lustre, mat,
that doesn't contain FBA in its base and coating. Could someone guide me
to a satin quality without FBAs?
Met vriendelijke groeten,   Ernst
Try: http://tech.groups.yahoo.com/group/Wide_Inkjet_Printers/
|      Dinkla Grafische Techniek      |
|         www.pigment-print.com        |
|                 ( unvollendet )                 |
Re:RC inkjet paper without fluorescents?
2010-09-30 by MartyF2938@aol.com
If you have a 2200, you'll have to cut the paper down to fit. I've used a
band saw, which works but not great. Clearly the best way is to use a mat
knife  and a good straight-edge. I only cut the paper as I need it. If I had a
great  deal of time, perhaps I'd cut the whole roll. But I don't know in
advance what  lengths I'd need.
Marty
Re: RC inkjet paper without fluorescents?
2010-09-30 by Paul
> pearl, lustre, mat, that doesn't contain FBA in its
I'm using Crane Museo Silver Rag for a "sepia tone" museum project because it appears to have no brighteners.  I'm not sure if this paper is marketed to Europe.
Re: [Digital BW] Re: RC inkjet paper without fluorescents?
> Paul
> www.PaulRoark.com
It is in better hands now since Intelicoat/Magicl\ufffde does the
distribution (and coating as I understand it) of Crane papers. Talked
with the man for Europe.  But it falls outside the RC category I think.
|                 ( unvollendet )                 |
[Digital BW] Re: RC inkjet paper without fluorescents- Museo Silver Rag not RC
2010-10-01 by Mark
Right, Museo Silver Rag falls in the inkjet paper category that we might call inkjet emulating "traditional fiber base" photo papers. If you immerse an RC paper in water, remove and then blot off the excess water it is nearly dry because the polyethylene layers sandwiching the paper core prevent the water from being soaked up by the paper core. Ditto for Inkjet RC papers that are microporous not swellable polymer coated. But try this experiment with a paper such as Silver Rag and, like traditional Fiber base papers used in a traditional darkroom, you will have a limp "Rag doll" (no pun intended) after removing from the water. It will take much longer to dry because the paper core is now wet.
cheers,
Mark
http://www.aardenburg-imaging.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <edinkla@...> wrote:
> > Paul
> > www.PaulRoark.com
> It is in better hands now since Intelicoat/Magiclée does the
> |                 ( unvollendet )                 |
