"kg4oqu" <schunn99@...> wrote:
> I bought a copy of Quadtone Rip 2.7, to try printing BO with claria inks first before trying MIS eboni6 inkset.
> But in Qtr, the printer is selected as Epson stylus photo 1400, and when the printing model is set at Quad1400-k6 or Quad1400,
I usually use the Quad1400-MIS option. There are black only profiles in there, but maybe not for Claria. (I'm using a laptop at the moment with an older version of QTR. So, I'm not sure what is in the latest download.) If you use one of the PK black only profiles you'll get the basic look -- which might be a bit greenish if it is really only the black ink.
I made some Claria profiles for the 260 that are at http://www.paulroark.com/BW-Info/260-Claria-QTR-Profiles.zip If you are familiar with QTR you can transfer these to a 1400 profile.
As you'll see in those profiles, and as noted further in http://www.paulroark.com/BW-Info/BW-Dye.pdf and http://www.paulroark.com/BW-Info/N-BW-VT-1-220.pdf, the Claria ink needs some LM added to get it to a neutral tone.
In connection with my current 1400 approach -- see http://www.paulroark.com/BW-Info/Eboni-4-Plus.pdf -- I've made some profiles that will print Claria inks also, but they are not configured for the OEM setup.
> My second question is in regards to using and installing eboni6 inkset when I buy it later. I have claria inks in my 1400 right now do I need to flush the print head before install the eboni6 inkset, or just install them?
It's always safest to flush a printer. That said, I just install the inks. I've run Eboni and Claria/Noritsu in the 1400 together for some time and see no evidence of incompatibility.
