On 01/20/2012 03:09 AM, Paul wrote:
> Ernst Dinkla<e.dinkla@...> wrote:
>> ... Considering the higher resolutions, smaller droplets
>> of today's inkjet printers and far better ...
> I think these same factors have made the need for small gamut much less important if one of the reasons is smoothness. At least with the 1400's 1.5 pl drop, I'm not seeing any reason not to use the Y and LM as toners, which is what I'm doing in the dye inkset I'm now printing with. (See http://www.paulroark.com/BW-Info/1400-Claria-Noritsu-2K2LK.pdf )
> Lower gamut inks or toners may make profiling easier, but I'm not even sure of that unless you take the low gamut all the way to monotone. I think the UT 3D inkset was harder for most to profile. The fewer "dimensions" or axes one has to correct, the easier it is. So, a monotone is the easiest, then a one-toner approach.
> I find the high gamut toners potentially easier to use because, at least in the dye set I'm working with, because so little is used that the tones can be altered without the need to re-linearize the profile.
>> Small Gamut inks should fit OEM drivers easier than any
>> other custom quad mixture I guess. Not
>> to mention adapted ICC color management.
> Yes, I think that is true and may be the main argument for them now.
> Being able to have profiling software work with the inkset was one of the reasons for and goals of the UT 3D inkset.
> Paul
> www.PaulRoark.com
Paul, good comments and some I considered too since I wrote that
message. A ressurection of small gamut may not be worth it but I also
see a wide variety of custom "quad" inks today, all kinds of curve and
"profile" adaptions to paper whites and coatings that ask for a devoted
user or developer, less flexibility when a certain "quad" inkset is
selected and printing from preferred applications (in my case Qimage) is
impossible, near impossible or asking for more steps in the proces. I
like QTR but as I have written a long time ago it would be nice if it
could function as a normal Windows driver (but still have the
linearisation etc) so I can hook it up straight to Qimage. Then there
are several thermal head printers that are nice candidates for "quad"
solutions but can not be used due to a lack of alternative drivers.
David's and your comment on pigment ink stabilisation is a thing I did
not worry about enough and should have worried about. Of course I should
check what printer integrated vibration technology could solve :-) A
nice coincidence, that other thread.
I expected that a small gamut ink solution today, 8 or 9 channels
pigment ink; Matte Black, Gloss Black, LK, LLK, Cyan Grey, Magenta Grey,
Cyan Grey Light, Magenta Grey light, Yellow Grey light, would deliver
more smoothness, better color consistency, more color toning choices +
split toning, easier adaption to new papers with profiling and a related
true soft proof, use of the OEM drivers available and run from preferred
applications with a wider selection of printers. I do not expect more
fade resistance than already possible with B&W print modes of the
different pigment printers.
For 5, 6, 7 channel printers with a reduced inkset skip either easy
gloss/matte switches or using less grey inks. There is something to be
said for less ink channels used more evenly so no ink stays long in the
system.
Met vriendelijke groeten, Ernst
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
| Dinkla Grafische Techniek |
| www.pigment-print.com |
| ( unvollendet ) |
