Epson 4990 Scanner Question
2012-03-21 by faeofavalon
Hey gang -
I had this problem in the past but must have resolved it somehow but
can't remember how. I use the Epson 4990 flatbed scanner to scan all of
my negatives. I am trying to scan in frames including the edges of the
film (so the numbers will show, etc) but when I select the area, the
image is pure white. When I select ONLY the image area, the image is
there. I tried deselecting the backlight compensation option in the
Epson software but it doesn't seem to do anything. Any advice would be
greatly appreciated :)
-AnnMariewww.annmarietornabene.net <www.annmarietornabene.net>
Re: [Digital BW] Epson 4990 Scanner Question
2012-03-21 by Ernst Dinkla
On 03/21/2012 03:07 PM, faeofavalon wrote:
> Hey gang -
Vuescan + border buffer at say 15% so it does not count the edges for
exposure.
Flare however will be increased if in scanning no mask is used.
Met vriendelijke groeten,   Ernst
Shareware now:
Dinkla Gallery Canvas Wrap Actions for Photoshop
http://www.pigment-print.com/dinklacanvaswraps/index.htm
|      Dinkla Grafische Techniek      |
|         www.pigment-print.com        |
|                 ( unvollendet )                 |
Re: Epson 4990 Scanner Question
2012-03-22 by faeofavalon
Ernst -
I use EpsonScan not Vue Scan so there isn't a buffer option. Is VueScan separate software I would need to purchase?
AnnMarie
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <e.dinkla@...> wrote:
> > Hey gang -
> exposure.
> Shareware now:
> |                 ( unvollendet )                 |
Re: [Digital BW] Re: Epson 4990 Scanner Question
2012-03-23 by Ernst Dinkla
On 03/22/2012 11:53 PM, faeofavalon wrote:
> Ernst -
> AnnMarie
Yes, but it is cheap for what it does. www.hamrick.com
However, there is another route. If you make a mask that covers the
edges of the film frame and do the preview + fix the exposure setting on
the measurement and then scan with the mask off. Would be possible with
Vuescan but I guess with Epsonscan too.
Another question; do you scan on the glass bed of the scanner and is
that in best focus on your 4990? Usually that is not the case.
Shareware now:
|                 ( unvollendet )                 |
2012-03-23 by faeofavalon
Ernst,
I will try what you said about masking it first. I neglected to mention the most important thing - the negatives are overexposed (simply because my Holga was set to "Bulb" without my knowledge!) so they are dense. HOWEVER, I can see through them when held up to light so the information is there.
On another subject, yes I do scan directly onto the glass but I never seemed to have a focus problem. Is using the mediocre film holders that Epson gives me, advantageous to focus?
AnnMarie
> > Ernst -
> > AnnMarie
> Shareware now:
> |                 ( unvollendet )                 |
On 03/23/2012 03:10 PM, faeofavalon wrote:
> Ernst,
> is there.
> AnnMarie
Depends, the Epson Perfection scanner models have no active focusing in
the scanner, it is a fixed focus design and not perfect. One 4990 may
have the focus on the glass bed, the other one 3 mm above the bed. In
theory the best focus should be halfway the height between the film
plane in the holders and the glass bed but the deviations are way beyond
that. Much is compensated by the wide DOF of the lens system but there
is something to gain there by adjusting the film holders. See this
article written 8 years ago on the 2450 model:
http://www.normankoren.com/Tutorials/Epson_flatbeds.html
If you want to include the frame edges there is the problem that little
film surface is left for keeping the film flat in any holder. If you
also want to reduce Newton rings etc that would occur in using glass in
contact with the film then there is only one solution that really keeps
the film plane and avoids Newton rings without loss of detail etc: wet
mounting. Doug Fisher makes custom wet mount holders and has some docs
on how to use them, There must be something I wrote among them. Doug's
holder has also adjustable nylon screws to get best focus. He has more
holder types too including anti-newton glass inserts.
http://www.betterscanning.com/
Shareware now:
|                 ( unvollendet )                 |
RE: [Digital BW] Re: Epson 4990 Scanner Question
2012-03-23 by Bob Rapp
I can vouch for Doug's film holders. I use the glass carrier for most scans
and have made masks for the unusual sizes of negatives I have scanned (like
616). I have found on my V750 the optimum negative height (emulsion side) is
3.5 to 3.6mm.
I have the luxury of using Silverfast with the scanner and have used the
product on my other scanners since 2004 and love (have adapted) the
software. I did try VueScan but found Silverfast much more competent and
easier to use. The only issue with Silverfast is their new version 8 which I
feel is a "work in progress" and should not be considered until it can match
the flexibility of the older software.
Speaking of scanning with the Epson flatbed scanners, the resolution from
the scanner leaves a lot to be desired. You will find that the registration
of the color channels will be skewed vertically as the scanner makes its
pass. Resolution above 2000 dpi is very limited. I you are scanning BW and
the scanner uses only one color channel to make the scan, then the
resolution can be 3000 dpi and above. I have measured my scanner and can
achieve about 3300 dpi - which is quite satisfactory for a flat bed scanner.
Resolution was determined with a USAF target I obtained for Lasersoft.
Bob Rapp
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Ernst
Dinkla
Sent: Friday, March 23, 2012 9:31 AM
Subject: Re: [Digital BW] Re: Epson 4990 Scanner Question
> Ernst,
> is there.
> AnnMarie
Shareware now:
| ( unvollendet ) |
