Hi Ben, I would suggest you look up Tim Parkin, a friend of mine, here in the UK, he does very reasonably priced drum scans, albeit that you have to do your own dustspotting. His website is http://cheapdrumscanning.com. I should say that although I have seen lots of his scans I don't use him myself as I run my own drum scanning business.
David Whistance
On 18 Apr 2013, at 15:40, "reallybelgium" <reallybelgium@...> wrote:
> Hi,
> Thank you all for your answers.
> I have been reading a lot last days, and I found out that there is a lot of buzz on the net about scanning.
> I will put some statements here that I found and that I think are correct.
> "Ask yourself why do you shoot medium or large format? To get truly fine prints, the whole chain must be right - from good technique during image creation and capture, through good processing, to good scanning, and on to good digital file processing and final output. If you're going to stick a thoroughly amateur device like a flatbed scanner in the middle of this process, you're going to have to expect thoroughly amateur results. The Epson simply isn't sharp, suffers from colour banding issues due to its cheap sensor, and offers poor shadow penetration." (source: http://www.imagescience.com.au/kb/questions/15/About+Scanning+Resolution)
> "Because those 'resolution' numbers are sheer fantasy. Sure, the file sizes coming out of those scanners are huge - e.g. 1 gigabyte file from 35mm - wow, that must be a great scan, right? Of course not. They may be huge but they are not optically sharp. They are full of useless pixels containing no real detail." They are full of interpolation."
> "The key issue with sharp prints is real resolution - that is, how much fine detail is actually in the image - as recorded by the capture system (camera or scanner), or originated by the image maker in digital production - and how much of this true detail can be actually expressed in a print. It's also important to separate detail itself from apparent sharpness (i.e. edge definition), as poor use of the unsharp mask so often demonstrates that fine detail and apparent sharpness are two very different things."
> (source: http://www.imagescience.com.au/kb/questions/32/Resolution+for+really+sharp+prints)
> I think I will follow the advice of Jerry and buy a cheap scanner (the one that Ernst proposed -Epson V500- seems to be ok) to have a good impression on the negatives.
> Then, for real scanning, I'll go to a lab in Brussels.
> (http://www.limelightlab.com/)
> They have a Hasselblad Flextight X5 and they scan for 2,5 euro, or for 12,5 euro, per scan. What I read about the high quality of this scanner (excellent optics, no plastic lenses like in the Epson range) is that a lower resolution scan of the Flextight X5 has better quality then a 'high quality scan' from an Epson scanner.
> Later on I can eventually buy a second hand drum scanner.
> Best,
> Ben Albu
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "reallybelgium" <reallybelgium@...> wrote:
> > Hi,
> > I want to scan 6x7 black&white negatives. Then I want to print them to A3+ size (max). I need to buy a -cheap- scanner. I want to get good/very good quality in my prints. I read about the Epson perfection 3200 photo scanner. Is it good enough to do this job, or do you advice another one?
> > Second question: I read about Vuescan software. Is this software really advisable above regular scanning software?
> > Thank you for your help/advice!
> > Ben Albu
> > Belgium
