Moire
Moire
2014-03-26 by Stephen Petegorsky
Peter - is the print something you can shoot or scan again, or do you not have access to the original?
If you can re-do it, try shooting it from a greater distance and/or at a rotation of 15-45 degrees from level.  If you don't have a RAW file and access to software like Phocus or something similar that has an option to treat moire, I doubt that you will have much luck trying to improve the file.
Good luck -
Stephen Petegorsky
Re: [Digital BW] Moire
2014-03-26 by Peter Marquis-Kyle
Thanks Stephen. Yes, I do have the original, and I am working with a
flatbed scan. I don't think rotating the original will help, since the
engraved lines run in various directions. There is no dot screen here,
only hand-engraved lines on end-grain boxwood. Did you look at the image
on the web page I linked to? -- you can enlarge it to see the engraved
lines.
Peter Marquis-Kyle
2014-03-26 by Ernst Dinkla
> lines.
> Peter Marquis-Kyle
Scan at the highest resolution possible, print at the highest resolution
possible (finest detail set) so upsampling is done on the data. Quite
often downsampling without anti-aliasing applied makes things worse.  If
the print may vary in size there is a good chance it will print with
less moir\ufffd at another size. If the moir\ufffd started with the scan and shows
in all sizes on the monitor it will appear in print too. Try to find an
angle in the scanner that gives the least moir\ufffd. Make sure that the
original is as flat as possible on the scanner. If the tools to take out
raster screening moir\ufffd do not work add some noise or grain. Vary the
image in size on the monitor, what is moir\ufffd at one size disappears or
changes at another size, if that happens you have better chances in the
print.
Met vriendelijke groet, Ernst
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
January 2014, 600+ inkjet media white spectral plots.
2014-03-27 by Peter Marquis-Kyle
> print.
Ernst, that was good advice to scan at the highest resolution possible.
I have just made a print that is perfectly free of moir\ufffd pattern.
I re-scanned the original using 2400 samples/inch (instead of 600).
Because the original is larger than the scanner platten I made three
overlapping scans, which Photoshop automatically merged for me. It was a
straightforward process, but slow. I made a flattened greyscale tif and
printed it at 3121.472 pixels/inch -- I'm not sure whether it was QTR or
the printer that down-sampled this to the printer's native resolution,
but I don't care. The result is just what I wanted.
Thanks Ernst, I appreciate your advice!
Peter Marquis-Kyle
2014-03-27 by John Castronovo
That works to get the pattern out of the scan and the print, but you're
still going to see it at certain sizes on a display.
Sent: Thursday, March 27, 2014 1:45 AM
Subject: Re: [Digital BW] Moire
> less moir� at another size. If the moir� started with the scan and shows
> angle in the scanner that gives the least moir�. Make sure that the
> raster screening moir� do not work add some noise or grain. Vary the
> image in size on the monitor, what is moir� at one size disappears or
> print.
I have just made a print that is perfectly free of moir� pattern.
Peter Marquis-Kyle
they are often being updated.
page.
them short.
membership without notice.
the membership.
Moderators. See \u201cGroup Topic, Rules and Guidelines\u201d in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \u201cOWNER\u201d AND
\u201cMODERATORS\u201d OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \u201cOWNER\u201d AND
\u201cMODERATORS\u201d OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
Yahoo Groups Links
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2014.0.4354 / Virus Database: 3722/7253 - Release Date: 03/26/14
