4800 pizza wheels
4800 pizza wheels
2015-10-21 by mccarvill@...
I'm getting pizza wheel marks on my new (to me) Epson 4800, with sheets of glossy paper. I had assumed that this printer’s vacuum transport mechanism meant no more of those ‘star wheel’ tracks.
I've tried auto and manual sheet feed.
No difference.
Under Paper Config > Ejection Roller Type, I've tried Auto, Sheet and Roll.
No difference.
Anyone have a solution for this?
Mark
Re: [Digital BW] 4800 pizza wheels
2015-10-21 by Paul Roark
My solutions: matte paper or dyes on glossy paper.
Also, holding the fluids to a minimum seems to help. Beware of gloss optimizer.
I'm sure different papers are affected differently, but I have not made or seen a good list of the best/worst in this respect.
It's really too bad about the artifacts of pigments on glossy paper. I'm probably going to take another shot at a glossy carbon print B&W approach soon -- not looking forward to this part of the problem.
On Wed, Oct 21, 2015 at 1:11 PM, mccarvill@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
No difference.
Under Paper Config > Ejection Roller Type, I';ve tried Auto, Sheet and Roll.
No difference.
Mark
RE: [Digital BW] 4800 pizza wheels
2015-10-21 by Elliot Puritz
Mark and Paul:
Would larger print margins help?
Elliot
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]
Sent: Wednesday, October 21, 2015 4:30 PM
To: DigitalB&WPrint
Subject: Re: [Digital BW] 4800 pizza wheels
No difference.
No difference.
Mark
Normal "pizza wheel" marks are not related to the margins. They are the result of the exit rollers touching the surface of the print, across the entire print. There are usually 2 wheels next to each other and they are about every 4 cm. They leave vertical tracks -- like little pin holes -- on the print surface. Most annoying.
With early inkjet printers (1280 era, I think) we could remove the exit rollers. With the modern printers they can't be removed without having a significant impact on the print quality, as far as I am aware.
On Wed, Oct 21, 2015 at 3:02 PM, 'Elliot Puritz' drpuritz@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Mark and Paul:
Elliot
To: DigitalB&WPrint
No difference.
No difference.
Mark
Ah…thanks Paul.
I had no idea that the gloss optimizer might be a factor.
I received a note about Canon's new 17 inch printer and inks, and a gloss optimizer is incorporated in the ink set.  However, I believe that the printer might feed printing paper at least partially via a vacuum.  If a vacuum is the sole means of feeding paper sheets then the solution is very ingenious.
It is too bad that there are no easy to use third party inks for Canon printers.
Elliot
Sent: Wednesday, October 21, 2015 6:16 PM
To: DigitalB&WPrint
Mark and Paul:
Elliot
To: DigitalB&WPrint
No difference.
No difference.
Mark
Re: 4800 pizza wheels
2015-10-22 by Fred Fischer
Have you tried “slowing” the advance of the media through the printer? That gives the ink/pigments time to dry before the pizza...
--Fred Fischer
2015-10-22 by mccarvill@...
I could try increasing the drying time, before the paper advances. But I suspect that just changing the paper feed advance would throw off the alignment. That said, those star wheels are pretty sharp.
I found a (blurry) video showing (I think) how to remove the exit rollers from the 4800. I may give that a try. I removed these rollers from my old Epson 1400 with no effect on print quality. But I honestly thought I was past that with a ‘pro’ printer. No such luck I guess.
Mark
Re: [Digital BW] Re: 4800 pizza wheels
2015-10-22 by Paul Roark
​Mark wrote:
> ... I removed these [exit] rollers from my old Epson 1400 with no effect on print quality.
That's interesting. The microbanding of the top and bottom of the image on the 1400, especially with QTR, is usually blamed on poor paper transport if only one of the rollers is engaged.
With the 1400, I was printing mainly on Canson Baryta, inspecting the prints with a loupe, and I found no issues. I left some extra top and bottom margin to minimize banding, but then I would have had to do that anyway using QTR.
Success.
It took about 5 minutes to remove the four small plates holding the star wheels (less time than it took with my old 1400).
The 4800 prints fine, and now with no pizza wheel marks.
I'm no engineer, but I have to wonder why the Epson team thought these pizza wheels necessary in the first place.
Mark
