VM and 1200 epson-pc
2002-06-18 by Paul Roark
Vincent, You wrote: >... VM and your curves on the 1200 epson on >a PC with Brightcube semi-matte and found if I use Vivid mode >and the nc curve the midtones and highlights are great but the >deep shadows go extreamly dark. Adobe RGB (1998) as opposed to sRGB might open up the shadows. If that is not enough, try a slight modification of the combined RGB curve or a curve in the transfer function area of the printer driver. The curves were profiled for Epson Archival Matte. I'm not sure how the paper you're using will print. Paul http://www.PaulRoark.com
