> >... paul, another question I need to ask is regarding your
> >workflows, if I use the same setups as you did
> >(1160, archival matte, MIS VM), would I get the
> >same results as yours? or is it also
> >dependent on the color configuration of my computer?
> The original workflow for the MIS VM inks calls for the "Photoshop 5
> Default" color settings under Edit, Color Settings. This includes the sRGB
> color space (which, as it turns out, is unfortunate).
> I use a PC, so the Mac performance would be different.
> I now have a working 1160 again, and I'll probably do a set of "no color
> adjustment," Adobe RGB curves that will be cross-platform and not affected
> by the PS 7 sRGB conversion glitch. I will probably do this for the
> vm-sepia inkset, which is what I now use and recommend (unless you really
> like cold, as opposed to neutral, prints).
> >Also from my understanding your workflow is not WYSIWYG, ...
> They are not WYSIWYG in the sense that the image is edited in grayscale, so
> the tones are not on the screen. The monitor and the grayscale image can be
> as comparable as in the Piezo workflow (and the monitor does not reflect the
> tone of that ink either). In the VM workflow, when you convert to RGB and
> apply a tone/partitioning curve for printing, you get a false-color image
> that you would not want to work with or save (although I have saved a few
> split-tone files in RGB).
> I have no idea whether one could make setup that would show the tones in the
> VM workflow. I think it is a minor issue, myself. I always print draft
> copies of images, because I don't consider any monitor good enough to rely
> on for a final print. Sometimes I'll print 4 small versions of the print on
> a single 8x10, each with a different curve applied.
> Paul
> http://www.PaulRoark.com
> _______________________________________________
> From: charlesdarwinau [mailto:imaginaryapple@...]
> Sent: Wednesday, July 10, 2002 10:07 PM
> Subject: [Digital BW] Re: [newbie] epson 1160 or 1200
> --- In DigitalBlackandWhiteThePrint@y..., "Paul Roark"
> <paul.roark@v...> wrote:
> > >... the different manufacturers
> > >providing the inks and also the 4-color 6-color difference.
> > >... I am trying to keep the cost as low as possible, so Piezo is
> > >prolly out of the question, MIS, with its workflows and
> > >new FS and neutral tones sounds better for me (and my wallet).
> > >... here in Australia 1160 are easy to get
> > >compared with 1200, however if hextone offers far
> > >superior quality then I
> > >don't mind spending a bit of time finding a 1200.
> > While some can see the difference in quality between the 1160 and
> the
> > hextones, I prefer the quads -- 1160 and 3000. They are more
> flexible and
> > easier to load inks into.
> > With the variable-tone inks, the quads don't have a "light" toner
> position.
> > Thus, some see the toner dots in the highlights. At viewing
> distance and
> > normal viewing conditions, I don't see them. At very close
> inspection I do.
> > I think the differences with real world prints is minor. Others may
> > disagree.
> > With the FS inks, which have a very light gray and no toner, I
> really doubt
> > anyone can tell the difference between an 1160 and 1200 output.
> > If you ever want to play with the Piezo driver and inks, the
> hextone Piezo
> > arrangement excludes the Epson driver workflows. This is a serious
> > limitation, as the Epson workflows have some advantages in some
> > circumstances. The ability to use alternative drivers and
> workflows can be
> > important, as none is perfect. When one has a glitch that shows up
> in a
> > particular print, being able to use a different one is really
> nice. The
> > quads can do this, the hextones cannot.
> > So, I recommend the 1160.
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
> - Good manners are required at all time. No personal attacks or "flames."
> - Before posting a question, search the message archives and the various resources on the homepage.
