MIS VM QuadTone Cartridges not loading in Epson 1280
2002-07-29 by daintreeriver2002
Has anyone had any problem loading the T007 and T009 cartridges with VM Quadtones in their 1280, or had "bad cartridges". I've done the cartridge replacement very carefully and no charging has begun -- both control panel lights remain solid. Help! Thanks!
2002-07-29 by dmeriwether16
--- In DigitalBlackandWhiteThePrint@y..., "daintreeriver2002" <workmantx@a...> wrote: > Has anyone had any problem loading the T007 and T009 cartridges with > VM Quadtones in their 1280, or had "bad cartridges". I've done the > cartridge replacement very carefully and no charging has begun -- > both control panel lights remain solid. Help! > > Thanks! I had a black T007 cartridge, brand new, that my new Epson 1280 would not recognize. I found the Epson black cartridge with no problems. Called MIS this morning, very friendly; said to take the chip off the Epson cartridge and put it on the MIS. Now works fine. So tomorrow a.m., I'm calling and asking them to send a second cartridge that they know is good. Give them a call on the 800 number.
2002-07-30 by jimhayes361
Some things MIS buries in their FAQ's and other places.... 1) You can blow the chips with static electricity. MIS line workers are instructed to touch a grounding pipe before picking up chips and sealing them in the black anti-static bags. Buy an $8 wrist strap from Radio Shack and clip it to your computer case or the center screw that holds an electrictrical outlet cover on (don't get shocked), or a copper water pipe that a plumber has grounded, etc. Wear it when handling chips. 2) Only use finger pressure to install chip, don't press hard with a screwdriver, etc. Recently, the holes on the chips are now shipped a little bigger so they go on the carts better. 3) Sometimes turning off and unplugging printer for one minute will clear it's buffer- and red lights. 4) There is a 2nd way to blow chips which true Epson carts seem immortal to but MIS chips seem to undergo. Sometimes, but not always, if the power is on, or even if the power is off but printer is plugged in, the previous chip data in the printer buffer zaps the chips through the electrical connector and confuses it permanently. I just wrestled with this this weekend installing a CFS. If this happens I put a genuine Epson cart set in and verify it is reading correctly, then I install new MIS chips on the carts, old ones are toast, and make sure they are reset (I have a QB7 resetter and a set of EZ plugs (nomorecarts) so I can rip out and reinstall the MIS carts). Now turn off printer, after it comes to rest, and the green light stops flashing, UNPLUG printer. Now, push down on the carriage head locking device- a white plastic pin sticking up just under and to left of head in parked position and at same time slide head to left and it will be free to move all the way to the left. Remove Epson carts and install MIS carts with new chips. Move head back to right again. Plug in printer, and turn on. 5) Of course it could also be that the cart is not properly seated. Or that connectors are bent. Jim H. --- In DigitalBlackandWhiteThePrint@y..., "dmeriwether16" <dmeriwether@s...> wrote: > --- In DigitalBlackandWhiteThePrint@y..., "daintreeriver2002" <workmantx@a...> wrote: > > Has anyone had any problem loading the T007 and T009 cartridges with > > VM Quadtones in their 1280, or had "bad cartridges". I've done the > > cartridge replacement very carefully and no charging has begun -- > > both control panel lights remain solid. Help! > > > > Thanks! > > I had a black T007 cartridge, brand new, that my new Epson 1280 would not recognize. I found the Epson black cartridge with > no problems. Called MIS this morning, very friendly; said to take the chip off the Epson cartridge and put it on the MIS. Now > works fine. So tomorrow a.m., I'm calling and asking them to send a second cartridge that they know is good. Give them a call > on the 800 number.
2002-08-04 by dmeriwether16
--- In DigitalBlackandWhiteThePrint@y..., "daintreeriver2002" <workmantx@a...> wrote: > Has anyone had any problem loading the T007 and T009 cartridges with > VM Quadtones in their 1280, or had "bad cartridges". I've done the > cartridge replacement very carefully and no charging has begun -- > both control panel lights remain solid. Help! > > Thanks! (After friendly call to MIS, but someone need to tell them that being friendly is just the start of good customer service): Here is the what the person on the telephone replied when I said that I had used their telephone instructions to take a good chip off my Epson cartridge to make the MIS cartridge work, and I wanted them to replace the defective cartridge with a good one. (Seemed like a resonable request to me.) 1) Bad cartridges "happen all the time." It appears they are getting lots of calls and taking them as a normal part of business. 2) MIS will not send a new cartridge. MIS will send a replacement CHIP which I can put on the cartridge, assuming that I am good with an Exacto knife and the little plastic nibs have not been damaged. 3) MIS does not test chips to see if they are good. She said the chips and cartridges are made, filled, and packaged in China. She said "there is no way we can know if the chips are good" - even the 2 loose chips that she sent to me as replacements. She impled that it was "their" problem, meaning someone else in China. The replacement chips arrived by express mail in 3 days. As I said, friendly and prompt and no clue that quality control is an essential element of long-term profit margins. So, the issue in choosing a system to print b/w is reliability before quality of the print. Why would I use a computer that I had to wonder if it would work each time I loaded the program? Why choose MIS if you are hoping the chip will work each time you change ink, etc. I switched to Mac because I was tired of computer problems getting in the way of just working on my images. [A very good switch, by the way. The only time I have a crash is when I am at work on my PC.] So why would I commit to a printer system when the company has a "that's the way it is" attitude toward defective equipment? Waiting three days to print or needing to buy extra cartridges that might work as backups (as suggested) did not seem to be a problem for the representative on the phone. (Of course, she was not the one trying to get the print out of the Epson.)
2002-08-04 by jimhayes361
Before you get really discouraged please see my post under this same thread, message #17245 from July 29th. There are some things you can do to insure survivalbility of chips. Once you get two-four known good chips, you are all set for using carts. The chips may or may not be DOA from MIS, you can't make that assumption. They are as delicate as any other circuit board- motherboards, RAM, graphics cards, etc. That is why they are shipped in anti-static bags. I will grant you however that I have never had the problems with chips off Epson carts that I do with MIS chips. Jim H. > (After friendly call to MIS, but someone need to tell them that being friendly is > just the start of good customer service): Here is the what the person on the > telephone replied when I said that I had used their telephone instructions to take > a good chip off my Epson cartridge to make the MIS cartridge work, and I wanted > them to replace the defective cartridge with a good one. (Seemed like a > resonable request to me.) > > 1) Bad cartridges "happen all the time." It appears they are getting lots of calls > and taking them as a normal part of business. > 2) MIS will not send a new cartridge. MIS will send a replacement CHIP which I can > put on the cartridge, assuming that I am good with an Exacto knife and the little > plastic nibs have not been damaged. > 3) MIS does not test chips to see if they are good. She said the chips and > cartridges are made, filled, and packaged in China. She said "there is no way we > can know if the chips are good" - even the 2 loose chips that she sent to me as > replacements. She impled that it was "their" problem, meaning someone else in > China. > The replacement chips arrived by express mail in 3 days. As I said, friendly and > prompt and no clue that quality control is an essential element of long-term > profit margins. > > So, the issue in choosing a system to print b/w is reliability before quality of the > print. Why would I use a computer that I had to wonder if it would work each time > I loaded the program? Why choose MIS if you are hoping the chip will work each > time you change ink, etc. I switched to Mac because I was tired of computer > problems getting in the way of just working on my images. [A very good switch, > by the way. The only time I have a crash is when I am at work on my PC.] So why > would I commit to a printer system when the company has a "that's the way it is" > attitude toward defective equipment? Waiting three days to print or needing to > buy extra cartridges that might work as backups (as suggested) did not seem to > be a problem for the representative on the phone. (Of course, she was not the > one trying to get the print out of the Epson.)
