RE: [Digital BW] PiezoTones: Are they ready for prime time ?
2002-08-09 by A. Huntley
I have tried several times and spent more $ than I care to admit to trying to get the Piezo system routinely working successfully on
my Epson 1160. Each time I have returned to MIS inks. I got so frustrated this last time 'round that I loaded up a brand new CIS
with MIS VM inks and tossed the PiezoTone ST cartridges in the trash! Microbanding, clogging, etc., is, regardless what Jon and
Co. say, a very real problem. They continually blame it on the hardware...I ain't buying it!
Case in point:  when I had the ST cartridges installed, I printed a few images one afternoon and returned the next evening to print
another one. A quick nozzle check--which I routinely do every time before beginning a print session--revealed about 1/2 the nozzles
not firing. I ran several cleaning cycles, let it sit overnight (can't tell ya how pleased I am to have to do this!), and the next day's
nozzle check showed that all but 1 or 2 were firing properly. I went ahead with my printing, anyway. Shouldn't have bothered because
banding was present once again.
OK...I've tossed the ST cartridges and installed MIS VM. Printed a couple of images and, then the printer sat for maybe 4 or 5
days. Upon turning it on, I did my usual nozzle check and, voila, perfect from the get go! Even the 1 or 2 that I could NEVER get
going with the Piezo cartridges were now OK. Can't say I've totally given up on Piezo--I'm stubborn and the paper profiles are a
very nice to have item--but, given the ability to modify the "color" of the print using Paul's VM inkset, and the results obtained, I'm
pretty much sold on MIS VM for now. I'm getting beautiful prints on EAM. I'm satisfied. Life is good.........
Hope this helps in your decision.
Best regards,
Alan
Sent:	Wednesday, August 07, 2002 8:59 AM
To:	DigitalBlackandWhiteThePrint@yahoogroups.com
Subject:	[Digital BW] PiezoTones:  Are they ready for prime time ?
Microbanding, clogging, and now clipping ...
As I debate making an investment into a new 1280 printer for PiezoTones
carts, some of you guys are continuing to scare me off.  How, prevalent are
these problems ?  Are any of you having trouble free printing with the new
inks (with the 1280 carts rather than CIS) and producing excellent prints ?  If
so, why are others posting such problems.
Now, I am starting to consider the prospect of buying the Epson 2200 and
buying custom printer profiles to try to produce my B/W digital prints.  Could
be less stressful until more of the kinks are removed from piezography.  Help
and guidance would be appreciated.
Re: [Digital BW] PiezoTones: Are they ready for prime time ?
2002-08-09 by Todd Flashner
This is minor to your main point, but for those who may not know, you WILL
get banding if any of the nozzles are not firing.
Todd Flashner
2002-08-09 by Martin Wesley
Alan,
What seems to continue to be true is that we all are having a wide variety
of experience with the different ink sets. Some people do just fine and
others have nothing but problems.
I have been running MIS-VM in one 1280 for 10 months or more with minimal
clogging or banding problems. A couple of strange incidents where a nozzle
cut out in the middle or a print and then kicked back in again before the
print was complete.
I played around with MIS-FS, FS Neutral, Sepia-VM and some blends of my own
on my second 1280 using cartridges. This gave me many more problems with
clogs. Just about every print session needed to be proceeded with nozzle
checks and frequently multiple nozzle cleaning cycles and a couple of
overnight sits.
I tried the Warm Neutral PiezoTone inks with a CIS in the same printer and
initially had zero clog problems. After several weeks I suddenly got some
banding which cleared up with a couple of nozzle cleanings. After that I had
to check nozzles at the start of every print session and usually do a
cleaning. After about 2 weeks of this I got nothing but good nozzle checks
and no more clogs.
The same printer was changed over to the Selenium PiezoTone with a new CIS
and I have had minor clogging problems. I do a nozzle check before each
print session and it is good probably 8 or 9 times out of 10. The checks
that aren't good clear up in 1 to 4 nozzle cleaning cycles. I have lost a
couple of 13x19 prints when a nozzle clogged mid print like the VM but other
than that okay. No quite as clog free as the first 1280 with VM but good
enough if I do my checks. Nothing compared to the clog nightmares I had with
the original Piezo on my 1200.
In general I have had much worse problems with clogs using cartridges than I
have using a CIS. This was true with my original 1200 and the original Piezo
inks as well. Other people have found the opposite to be true. They get
fewer clogs with cartridges and have a terrible time with the CIS.
The only explanation I can offer is printer to printer variation. Or perhaps
climate extremes.
In the mean time I am printing away with the Selenium PT and pretty much
like it better than anything else I have tried. I am sorry to hear they
worked out so poorly for you.
Martin Wesley
http://www.borderless-photos.de/guests.html
Sent: Thursday, August 08, 2002 6:11 PM
Subject: RE: [Digital BW] PiezoTones: Are they ready for prime time ?
> Best regards,
> Alan
> From: lawrencetrek [SMTP:ltitle@...]
are
?  If
Could
Help
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
page.
them short.
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
2002-08-09 by lawrencetrek
Guys,
You're not doing a good job convincing me to rush and buy the PT inks.  The
MIS inks don't seem to be clog- and banding-proof either.
Maybe I can live with less than "dead nuts neutral" B/W prints from a custom
profiled Epson 2200.  This would still give me the option of toned images,
duotones and printing the occasional color print as well.
I want to make my final decision soon.
Sent: Thursday, August 08, 2002 7:58 PM
Subject: Re: [Digital BW] PiezoTones: Are they ready for prime time ?
> Guys,
The
custom
Lawrence,
Just to keep some perspective, my wife was having some problems getting a
good color print from her 1270 with Epson dye inks on ColorLife paper. I ran
a nozzle check for her an found multiple clogs. It took 7 nozzle cleaning
cycles to get the clog to clear and to make a good print. This printer has
never run anything but genuine Epson ink.
As I posted earlier. None of these printers, inks or workflows is perfect.
They all have limitations and certain problems. I can guarantee that
whatever inkjet technology you pick, you will encounter clogging at some
point. Other than the original Piezo inks, I have not seen any clogging
issues that would stop me from recommending any of the other Piezo inks or
the MIS inks.
You have to make your own choice and start somewhere. If you are lucky, you
will be content with what you start with. For many of us it has been a
matter of many trials to find something that suited our taste balanced
against limitations, functional problems and cost. I look forward to the day
when people can visit a gallery or museum an see fine prints made with all
these processes and will not have to make a blind decision based on a bunch
of text messages on the Internet.
Martin Wesley
2002-08-09 by Robert Morrison
I've had many clogs/bands in all of my printers with both the MIS FS and
FS-N inks...of course also with the original Cone BW inks, Color Piezo, MIS
Perpetural, Indelibles...and of course Epson OEM dye inks.  Clogged nozzles
are a way of life if you print a lot.  Count your blessings if you haven't
had a problem yet...some printers just seem to be better than others...maybe
you got one...if you have a lot of printers like I do you are bound to get
some rotten apples.  There isn't a week that goes by when my Dad's good old
Epson 1200 with Epson OEM inks doesn't get clogged nozzles.  He does a
couple of head cleanings and starts printing again...just like the rest of
us.
Robert
2002-08-09 by vinyo88
I have been using the MIS VM inks for several months now and allways
get a nozzle clog with the black ink only even after only 24 hrs. If
I print today, tomorrow the black will have a clog that clears after
2-3 cleaning. Does anyone know what might be causing this.
Vinny
http://www.wulfsden.com
--- In DigitalBlackandWhiteThePrint@y..., "Martin Wesley"
<mwesley250@e...> wrote:
> Alan,
variety
and
minimal
nozzle
before the
> print was complete.
of my own
with
nozzle
of
> overnight sits.
printer and
got some
that I had
a
checks
> and no more clogs.
new CIS
each
checks
lost a
but other
good
had with
cartridges than I
original Piezo
get
Or perhaps
> climate extremes.
much
they
> Martin Wesley
> From: "A. Huntley" <prasepe@a...>
> To: <DigitalBlackandWhiteThePrint@y...>
time ?
to trying
frustrated
trash!
a few
time before
(can't
went ahead
a couple
perfect
totally given
the "color" of
on EAM.
> > Best regards,
> > Alan
> > From: lawrencetrek [SMTP:ltitle@i...]
> > To: DigitalBlackandWhiteThePrint@y...
PiezoTones
prevalent
> are
with the new
excellent prints
> ?  If
2200 and
prints.
> Could
piezography.
> Help
Polls and
wish to
this same
> page.
messages to keep
> them short.
header.
various
2002-08-09 by Truman Prevatt
I am beginning to wonder if there are some environmental issues
associated with clogging - say low humidity causing drying out in the
tips of the print heads. I remember when I lived out west, we would have
the problems with our ball point pen supply. Half of them you would get
out of the supply cabnit didn't work or you got out this slimy glob of
ink out the first time you used them. We stopped keeping a large supply
on hand and ordered smaller numbers more frequently and that seemed to
help. When I've lived in humid climates, MD, VA and FL, I seldom see
this - in fact I've never seen it in FL. This had to be a evaporation of
the water from the ink in the pen tips leaving it thick. Could the same
thing be impcating injets?
Truman
> Vinny
Todd,
I fully realize that one gets banding if all nozzles are not firing perfectly. However, I have had banding with Piezo with perfect nozzle
checks. I guess part of my point is that this last time with the Piezotone inks I couldn't EVER get a totally clean nozzle check. To be
honest, I really don't know if the system would have eventually worked. I don't have the time to "baby" my printer hoping to get
acceptable prints from it.
As others have pointed out, whatever works for you WORKS, and is good. For me, that's Paul's VM inkset from MIS.
Best regards,
Alan
Sent:	Thursday, August 08, 2002 7:08 PM
Todd Flashner
2002-08-10 by A. Huntley
Martin,
I totally agree with what you've said here. I think the problems most of us experience are driven primarily by two things:  1) digital printmaking is really in its infancy and there will naturally be "growing pains", and 2) I believe and fully agree with you that printer manufacturing will, in the normal course of mass producing any product, lead to variations. Therefore, it is easy to believe that my printer may clog, band, etc., and yours doesn't. Jon's last e-mail to me was very understanding and I think he was trying to tell me, in a nice way, that perhaps my 1160 was not up to the task of handling the tight dither pattern of the piezo driver. Made some sense to me...after all, the 1160 was a $300 printer when you could walk into your local Staples and pick one up off the shelf.
Overall, I would say that I've had less problems with a CIS on my 1160. I just couldn't convince myself to invest in the cost of 4 oz bottles of PT-ST without knowing for sure that I had a high probability of everything working out. I don't have that kind of $$ to throw away. Jon said that Cone Editions buys lots of printers and they weed out the duds selling 'em on eBay. Personally, I don't have the financial resources to "buy and sell" printers until I stumble across one that is acceptable. I guess that's really at the heart of what I'm trying to say... The beginning digital imager should be aware of the possible pitfalls involved. I didn't have the opportunity of learning from all the fine folks on this forum before "diving in." I'm learning a lot now, though!
As I said before I have not totally given up on Piezo. Maybe one day I'll have the money to invest in a "better" printer for this software and inks and all will be good. I, for one, like the "color" and tonality that the PT-ST inkset lays down on Photo Rag. I was tremendously disappointed that it didn't work out. Hmm...maybe an Epson 1280, now that a rebate is available, would work well. According to what I've read from others on this list, the 1280 seems to have minimal problems with the new PT inks. After all, there is a lot to like about Piezo: the minute tonal differentiation, dotless output, the paper profiles, the simplicity of the workflow, to name a few. I'm not casting stones at IJM, Jon, or Piezo, just, maybe, letting off some steam.
Thank you to all for listening.
Best regards,
Alan
Sent:	Thursday, August 08, 2002 7:44 PM
Alan,
print was complete.
overnight sits.
and no more clogs.
climate extremes.
Martin Wesley
> Best regards,
> Alan
are
?  If
Could
Help
page.
them short.
