Re: [Digital BW] Small Gamut (was Density Meas .... etc.)
2002-08-12 by Martin Wesley
Ernst, I would love to see MIS or ConeTech come out with an ink set similar to the Lysonic E but done with pigment inks. The problem in mixing them up yourself is keeping the proper overall density. Even in blending similar inks like MIS-FS Standard and Neutral some density shifts were obvious. I assume that the companies have a great deal of expertise in this but I would not want to try it myself even with a spectrophotometer. You would have to do many trials mixing up an ink, loading it into a K cartridge, printing a mono-ink wedge, take readings, compare them to the visual density you want for the particular ink position you are mixing up, adjust your formula and do it all over again until you got it right. I can be done but a lot of work from scratch. Martin Wesley http://www.borderless-photos.de/guests.html ----- Original Message ----- From: "Ernst Dinkla" <e.dinkla@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Sunday, August 11, 2002 10:25 PM Subject: [Digital BW] Small Gamut (was Density Meas .... etc.) > > ----- Original Message ----- > From: "Jerry Olson" <jerryolson@...> > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Sent: Monday, August 12, 2002 6:23 PM > Subject: Re: [Digital BW] Density Measurements on 2200 Wedges > > > > Robert, they appear to have greatly improved the metamerism with the SG > > inkset. If you print to a nice neutral in daylight, the prints look just > > a tad sepia in tungsten, but not much. It's a great improvement from the > > magenta metamerism they used to have. > > Is a SG inkset more complex than mixing a 4 tone quad inkset with a CMYK > inkset of the same manufacturer ? > The most simple mix would be 50% Y to 50 % (yellow)grey, etc. A MIS mix of > pigment inks must be the easiest. > Spectratone with Wide Spectrum for a dye version. As I understand it > American Ink was the only other manufacturer of a SG inkset and they never > launched it. Could be a patent issue (Joseph Holmes) of course. > > Ernst > > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or &amp;quot;flames.&amp;quot; > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage.
> > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
