Martin:
Wasn't this a thread topic earlier this year?
At least for a 4-ink system, I am reasonably convinced that a purge
print yields representative values. I am not certain about the 6-ink
systems (esp the PC and PM position inks). ** I should have expressed
my uncertainty in my previous post.** I agree that loading up black
carts with each of the 5 shades of gray in a hex-set would work well,
but is a little costly. I guess it boils down to how accurate the
results need to be or how the results will be used. I suppose one
could also try a smear test (drawing the ink out from heavy
application to a feather edge on a sheet of paper) for each ink as an
alternative.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@y..., "Martin Wesley"
<mwesley250@e...> wrote:
> Jeff,
> Would you get a good reading this way or would it be better to load
each ink
> in a Black cartridge and make a Black Only print? I am wondering
with the
> purge file whether the driver give you a perfect separation.
> Martin Wesley
> http://www.borderless-photos.de/guests.html
> From: "jrandall1149" <jrandall@c...>
> To: <DigitalBlackandWhiteThePrint@y...>
> Sent: Wednesday, August 21, 2002 1:37 PM
> Subject: [Digital BW] Re: Epson 2000P what's different ?
> > I agree with Paul, these are probably mixing ratios. I have also
> > gotten a similar response from Bob Zeiss in the past.
> > If you are interested in the actual reflective densities, then
run a
> > 6-ink purge print and check the densities with your scanner or
> > directly with a densitometer.
> > Jeff Randall
> > --- In DigitalBlackandWhiteThePrint@y..., "a_pettit_jr"
> > <a_pettit_jr@y...> wrote:
> > > I just received the FS set.
> > > I called MIS and they spec'd the densities as
> > > B 100 %
> > > C & PC = 28.5 %
> > > M & PM = 7.2 %
> > > Y = 3.25 %
> > > The Yellow seems correct, but Magenta spec seems strange ...
> > > I'd have anticipated 72 % rather than 7.2 %
> > > I need to test them to be sure ...
> > > Alex
> > Please visit the Group Homepage to check the Files, Bookmarks,
Polls and
> other resources as they are often being updated. The page is at:
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > If you wish to receive no emails or just a daily digest, or you
wish to
> unsubscribe, please edit your Membership preferences by visiting
this same
> page.
> > Please follow these basic guidelines:
> > - Include your full name with your message.
> > - Include the address of your website, if you have one.
> > - As threads develop, trim off excess portions of earlier
messages to keep
> them short.
> > - As the topic of a thread changes remember to change the subject
header.
> > - Good manners are required at all time. No personal attacks or
> &amp;quot;flames.&amp;quot;
> > - Complete your Yahoo profile.
> > - Before posting a question, search the message archives and the
various
> resources on the homepage.
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
