CIS more reliable than carts in general?
2002-09-16 by thronxx
Hello all,
I have a new Epson 1280, checks out fine. I want to set it up for
B/W, but have heard that both MIS and Cone are having problems with
the 1280 carts. I don't need the problem, especially if it's
avoidable.
Generally speaking, and referring specifically to my 1280, will a
CIS perform better than a cart? I was under the impression that a
CIS system is a bottle and tube running to what is functionally a
cart at the printhead anyway.
Any suggestions would be appreciated. I'd like to keep my hair-
pulling (whatever's left) to a minimum.
Cheers, Jeffrey Fass
Re: CIS more reliable than carts in general?
2002-09-17 by Martin Wesley
--- In DigitalBlackandWhiteThePrint@y..., "thronxx"
<jeffrey.fass@v...> wrote:
> Hello all,
> avoidable.
Jeffrey,
I have always found the CIS to be more trouble free than the
cartridges, if for no other reason than the fact that most problems
occur when cartridges are installed and this is a one time job for
the CIS. You are correct in that the CIS is nothing more than
cartridges attached with tubing to bottles of ink. As the print head
pulls ink out of the cartridge fresh ink is pulled from the bottles.
Perhaps since the cartridges are always full there are less
headaches. People have reported some problems when they let their
bottle run too low but I have not encountered this.
Martin Wesley
2002-09-17 by jim hayes
--- In DigitalBlackandWhiteThePrint@y..., "Martin Wesley"
> > Hello all,
with
> > avoidable.
> Jeffrey,
> the CIS.
I'd agree on this point. I used self-filled carts on my 1280 for seven
months. Occasionally (like every third time I installed them) I would
get air trapped in the head and the nozzles would take about three
cleanings and one or two purge patterns to clear. I could usually get
them running in ten minutes or so, it was a mild problem. A little
worse was when, also because of the air, a new cart would sputter ink
blobs for a short period into the printer bed. I could avoid this by
running two or three cleaning cycles first, but not always was I left
with a clean printer even doing this.
> headaches.
I have run a MIS CFS for 1 1/2 months now with little problems. It is
as reliable as carts, except for the install problem noted above with
carts. Something I am worrying about with the CFS that the carts do
NOT have is possible evaporation of the K and to a much less degree,
the C ink in the bottles. My only evidence for this is I observe
deposits of ink caked onto the upper sides of the k bottle, a little
in the c bottle. I do not know if this over time will
increase/decrease/remain unchanged the performance of the ink thru the
head and onto the paper. The deposits in bottle seem to increase over
time. I have heard others talk of evaporation in the bottle, and also
from the tubing.
I'm sorry I can give no more resolution on this observation. I don't
even know if it's a real problem yet.
Jim H.
> Martin Wesley
