Multiple MIS Inksets used on one printer
2002-10-23 by donbga
I've been thinking about the possibility of using more than 1 inkset
on one printer. That is to say, currently I use MIS VM quadtones with
my 1160 using CFS carts.
Would it be feasable to set up a different MIS inkset such as the VM
Sepia with another set of CFS carts, purging the heads when swapped?
I occasionally have to pull a cart out to get it reprimed every so
often, as long as one cart set was left in I would think this method
would allow flexibility of inksets.
Don Bryant
Re: Multiple MIS Inksets used on one printer
2002-10-23 by Jeff Randall
Don:
I swap CFS units on my 1270 between MIS Archival Color and FS-E with
no problems.  Two things to remember: the more frequently you swap,
the more likely you are to introduce air into the printheads, and the
longer a CFS unit is unused, the more likely it is to develop sludge
in the lines due to the water/solvent permeability of the tygon
tubes.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@y..., "donbga" <dsbryant@m...>
inkset
with
VM
method
> Thanks,
> Don Bryant
2002-10-24 by donbga
Jeff,
sludge
> tubes.
What are the consequences of getting air inside the print head(s)? A
blocking of ink flow obviously but would that be a fatal situation
requiring Epson service?
How does one detect sludging of the feeder line? And how do you
recommend clearing it?
And as Jerry Olson pointed out the MIS rivets don't provide a 100%
seal. What do you use?
Thanks very much for your help.
Don Bryant
2002-10-24 by Jeff Randall
Air trapped in the printhead is not always "fatal".  Sometimes just
letting the printer sit over night is all that is needed for the
bubbles to clear.  After that, if you are into this, its time to
inject bubble free cleaning solution, either Windex or 9 parts water
to 1 part household ammonia, through the printhead using a syringe
and tubing (search the archives here or visit the MIS or Inkjetmall
web sites for lots of info) or take it to your local Epson repair
shop.  BTW, Epson folks strongly advise against cleaning your
printhead your self.
Detecting blockages in the tubing is difficult. I often see small
bubbles traveling along the tubing thus I know the ink is moving.
Sludge can also build up in the carts.  A CIS/CFS cart will not last
forever.  To clean the tubing is easy.  Just disconnect them and
blow/suck water through them with a syringe and reinstall.  Some
folks have had luck with the system repriming itself.  I find that I
need to pull ink from the bottom exit port of the cart to reprime.
MIS sells a bottom fill adaptor that works well.  You can pull the
ink through and squirt it back into the appropriate bottle.
I find the rivits to work very well for me, but you could always
place some black electrical tape (or your favorite tape varity) over
the rivets.  Remember, the cart is vented, therefore it is not
hermetically sealed.  Make sure to store the carts in the upright
postion as if they were installed in the printer.  Again, remember
the CIS/CFS system will not last for ever, so don't store them for
long periods of time and expect instant success.
Your mileage may vary!
Hope this helps.
Jeff Randall
wrote:
> Jeff,
> the
> sludge
> > tubes.
A
> Don Bryant
Opps:  CIS/CFS carts are sealed, regular carts are vented--sorry for
any confusion.  jr
wrote:
> Jeff,
> the
> sludge
> > tubes.
A
> Don Bryant
Re: more clog advice was Multiple MIS Inksets used on one printer
2002-10-25 by jim hayes
--- In DigitalBlackandWhiteThePrint@y..., "Jeff Randall"
I'd pretty much go along with this, maybe wording it like "usually" it
is not fatal. Folks seem to want to get a cart running immediately
with many cleaning cycles and etc, when all they should be doing is
turning off printer and waiting overnight. I have this situation right
now, am hoping I won't have problems after it has a rest...
However, I avoid direct injection although others have had good sucess
with it. I usually install Epson carts first and run them for awhile.
This clears up any problem the head is causing- the rest will probably
be due to the CIS/CFS. The CFS is so easy and cheap to replace I
would just do this, but I have once restored it with the bottom fill
adapter method Jeff mentions. If I had a CIS instead, I think I would
install new carts and flush the lines. I would probably also at least
replace the K ink bottle.
Actually what I AM doing is trying to get back to self filled carts as
I just can't keep a CIS or a CFS working in my climate it seems.
<snip>
  I find that I
<snip>
> the rivets.
Or you can use EZ-Plugs from anyplace that sells the nomorecarts CIS.
But keep the receipt because the plastic cracks very easily, some
suspect as a result of the solvent in the ink! I keep two pairs and
keep sending in one pair as it cracks. Some day nomorecarts may wonder
why they have to always replace these things and get a better design.
But the EZ-Plugs have less tendancy to distort the rubber seals than
the MIS Rivets (smaller diameter) and are easier to insert/remove. But
cost $15/set.
Jim H.
> Hope this helps.
> Jeff Randall
> wrote:
> > Jeff,
and
> > the
> > sludge
> > > tubes.
> A
> > Don Bryant
2002-10-27 by michaelrosensf
--- In DigitalBlackandWhiteThePrint@y..., "jim hayes" <jimhayes@f...> wrote:
<snip>
<snip>
What's your strategy for keeping track of how full the carts are, or do you buy
new carts each time? I understand that the non-chipped Epsons, like the
1160, count the number of prints rather than measure the amount of ink used
and that it's very bad to try to print with no ink.
Michael
2002-10-27 by jim hayes
--- In DigitalBlackandWhiteThePrint@y..., "michaelrosensf"
> <snip>
> <snip>
do you buy
ink used
> Michael
1160 Epson carts have no poppet valves and are not self sealing.
Therefore there are more chances that air will be introduced if
removed and put back in after intial seal is broken. I have risked it
once or twice in an emergency but I don't recommend it to others when
serious clogs need to be cleared. You have enough things to worry
about without the Epson cart itself causing air pockets. I almost
always just forked up the $$ for new carts on my 1160's.
The 1270/1280/1290 Epson carts ONLY (not the 3rd party carts made in
China, etc that you can buy empty or prefilled or in CFS/CIS systems)
have poppet valves which are little seals that almost instantly seal
each exit port when removed from printhead nipples. These carts CAN be
re-installed with a few caveats....Bob Zeiss at MIS told me once he
thought they were truely good for only about three removals before
they started to get air in them. This I don't know about- they always
worked well for me. The second caveat is from Epson- that once outer
package foil is opened, cart should be discarded within six months. I
sometimes put electrical tape over the vent holes for storage.
You will know it when you run out of ink- it happens rather fast, at
least the two times it happened to me. YMMV since my experience is
modest with this. ANd it is bad to let the nozzle remain dry- I always
tried to have a fresh good cart ready to pop in within a few minutes
at most. Leaving it dry overnight is asking for big trouble.
BTW, I and others find that Epson carts will clear clogs. But when I
had bad ink, such as the old Piezo ink, and just last week, evaporated
 MIS VM ink which caused an increase in mottling, that Epson cart
running clears some (50-90%) of the problem but even if fresh ink is
later introduced it doesn't fix the problem 100% although your nozzles
may be clear. I seem to have a residual VM mottling problem even after
the Epson treatment. Others have had sucess with direct injection into
head with Fantastik to clear the old Piezo ink problem "DSS" or the
"Greenies".
Jim H.
