1270 Contact tines
1270 Contact tines
2002-10-29 by ed0212000
Hello all:
Is it possible to repair or replace the contact tines in the 1270
print head with out going to EPSON.
Ed Blake
Nashua, NH
blakephoto@...
Re: 1270 Contact tines
2002-10-29 by Jeff Randall
I think the printhead, cartridge holder, cart contact tines, the two
small circuit boards with the ribbon cable slots (ie., the entire
printhead assembly) is sold as one unit.  If memory serves me right
the 1270 printhead is about $145US.  You can order one from your
local Epson repair shop.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@y..., "ed0212000"
<blakephoto@a...> wrote:
> Hello all:
> Ed Blake
> Nashua, NH
> blakephoto@a...
[Digital BW] Re: 1270 Contact tines
2002-10-29 by Bill Agee
>Jeff Randall
That's correct. Plus the Labor cost to install...I had an estimate of
about $245 from the local "authorized dealer" in my area for the
whole job....Though I hated to do it, I trashed the printer and went
for a 1280 instead with the rebate...I was afraid something else
would have bombed later on...it was a great printer until the tines
broke off.   The dealer claimed they broke while they were trying to
repair them...go figure!
Good luck,
Bill Agee
bill agee studio
capistrano beach, ca / laguna beach, ca
http://www.redsilver.com
Re: [Digital BW] 1270 Contact tines
2002-10-29 by Peter Lindman
Ed,
I've fixed this problem (I mistakenly installed a cart without the chip).
Try using a loupe for magnification and an exacto knife to bend them back
into place. I've been using the repaired 1280 for almost 4 months with no
problems, though I have to admit I installed  a CIS as soon as I could in
order to minimize the cart exchanges.
Peter Lindman
on 10/28/02 7:17 PM, ed0212000 at blakephoto@... wrote:
> Hello all:
> Ed Blake
> Nashua, NH
> blakephoto@...
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other
> resources as they are often being updated. The page is at:
> page.
> them short.
> &amp;amp;quot;flames.&amp;amp;quot;
> resources on the homepage.
2 1280s on one mac?
2002-10-29 by Matt M
I went and bought a CFS system from MIS, based on the conversations
on this list, and then realized I still need a color printer, so
bought a second 1280.
My question is: can I have both printers, one dedicated to black and
white and one to color, hooked up to the same machine or will I have
a conflict and have to change printers every time I want to print?
Thanks for all the helpful info!
Matt
RE: [Digital BW] 2 1280s on one mac?
2002-10-29 by Ton Guiking
It depends on the software of your OS, usually you can set one printer
as default, and opt for another one when needed.
FWIW,
Ton Guiking
> -----Oorspronkelijk bericht-----
> Van: Matt M [mailto:matt1729@...]
> Verzonden: dinsdag 29 oktober 2002 17:10
> Aan: DigitalBlackandWhiteThePrint@yahoogroups.com
> Onderwerp: [Digital BW] 2 1280s on one mac?
> Matt
> ---------------------~--> 4 DVDs Free +s&p Join Now
> http://us.click.yahoo.com/pt6YBB/NXiEAA/jd3IAA> /ucIolB/TM
> Bookmarks, Polls and other resources as they are often being
same page.
keep them short.
header.
Re: 2 1280s on one mac?
2002-10-29 by Stephen Kobrin
Matt,
I am not sure about a Mac, but on a PC you can run two or more
printers through USB connections.  I have a 1280 and a 1200 on my PC
at this point and just select the one I want to use throug the print
function in PS.
Steve
--- In DigitalBlackandWhiteThePrint@y..., Matt M <matt1729@r...>
and
have
> Matt
I am on a mac running OS 9.1. Margaret said she thought it shouldn't
be a problem, I just need to go to the chooser and tell the driver
which usb port to print to. I will have to give it a try when the
printer gets here but I was kind of hoping that I could name the
driver epson 1280 bw and epson 1280 color, or something like that.
It may be that it was never meant to be set up like this and I will
have to change my work flow to accomodate.
What do other people do with a duel printer set up if they are twin printers?
Matt
>FWIW,
>Ton Guiking
printers
2002-10-29 by Stephen Petegorsky
Matt - I currently run three printers (a 2200, an 1160 and a 1280) with USB
connections off of my Mac (G4).  It's just a matter of picking the right
printer from the chooser (I'm still using OS 9.1) before you print.
Re: [Digital BW] 2 1280s on one mac?
2002-10-29 by bgs
You turn the one you want to use on. If you put them both on at the same
time you will have a fun time with the USB ports.
Sent: Tuesday, October 29, 2002 1:15 PM
Subject: RE: [Digital BW] 2 1280s on one mac?
printers?
> Matt
> >FWIW,
> >Ton Guiking
page.
them short.
2002-10-29 by dw_carter
Should be no problem to run several printers at same time or run
same printer from two computers.  What I did was set the printers up
on a small network.  My wife and I both have a computer in the same
room.  That way each one has an address and files can be put in the
que from either computer.  Or at either printer.  Besides 1280's I
also have a laser BW on the same network.
Hope this helps, Dave
the same
> From: "Matt M" <matt1729@r...>
> To: <DigitalBlackandWhiteThePrint@y...>
shouldn't
driver
that.
will
twin
> printers?
> > Matt
printer
> > >FWIW,
> > >Ton Guiking
Polls and
wish to
this same
> page.
messages to keep
> them short.
subject header.
various
2002-10-30 by Jerry Olson
You can use both printers at once, but will have to change chooser icons
before you print with each.
jerry
> Matt
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
> - Good manners are required at all time. No personal attacks or &amp;amp;quot;flames.&amp;amp;quot;
> - Before posting a question, search the message archives and the various resources on the homepage.
2002-10-30 by Margaret Lucas
>You can also rename the printers to avoid confusion if you like.
anyone know how to do this onna MAC?
thanks,
Margaret
2002-10-30 by Sam A. McCandless
On my Mac, also still under 9.1, I have two 1160s, also one for B&W
and one for color, but only one (not re-named) driver. So I just turn
on the printer I want (otherwise I leave them covered, and turned off
so the heads will be parked on the pads and not dry out). Having
turned on the one I want to use, I try to do a nozzle check, and
change the USB port selection in the Chooser if the nozzle check
doesn't work (I don't leave paper in the printers).
This is less trouble than it sounds like because when I first turn
the computer on each day, I Nozzle-Check and do a Clean if necessary
(rarely), on each printer, doing the B&W first and therefore leaving
the Chooser, by default, on the color port for the rest of the day
unless I print some B&W. If the humidity were very low where I live,
I would do the same thing each day before shutting the computer down
overnight. And I would do it anyway if I didn't get perfect
Nozzle-Check prints almost every day, both with MIS VM Sepia-Neutral
and with Gen4 color (with VM black swapped in for Gen4 K).
Sam McCandless                 samcc@...
>Matt
2002-10-30 by Matt M
Jerry,
Since both printers are 1280s, they both use the same driver, Right?
So I only have one icon. Or can I install the same driver twice?
matt
>jerry
I think you have to rename one with the epson namer.
Jerry'
Don't think you can use the same driver simultaneously without renaming
the printer.
> matt
> >jerry
The Epson Namer is only supposed to be used in localtalk and ethernet
situations, as I discovered on this site:
At 12:55 PM -0500 10/30/02, Matt M wrote:
>An Epson printer is setup in the MAC network using the Epson Net!2
>for MAC. Epson Net!2 allows you to rename the printer and assign it
>to an existing zone. If the Epson namer is installed, do not use it.
>It is intended for LocalTalk connections.
http://www.uktsupport.co.uk/epson/Inkjet/sc900n.htm
Since I am working off of a usb hub, I don't think my situation qualifies.
Matt
2002-10-31 by billstrong50
I routinely run an Epson 1270 with color and an Epson 1160 with VM
simultaneously on a Mac.
 I use a PowerMac 733 with Classic 9.2 running under OS 10.2. I print in the
background with both printers using the standard Epson System 9 drivers with
Phototshop 6.0 running in Classic 9.2 within 10.2.
As mentioned previously you do have to select the second printer with
Chooser after you get the first printer started. I also surf the internet or work in
photoshop or other programs while both printers are working.
I used to crash in 9.1 fairly frequently; however, since I have been running 9.2
within 10.2, I have not had a crash. By the way, I have not inadvertantly
crashed 10.2 thus far.
I have had no success with the OS X Epson drivers as far as getting what I
want out of a printer without a lot of hassle but have had some success with
the Gimp drivers for non-photographic printing. I have not tried the Gimp
drivers to any extent for photographic printing because the 9.2 solution works
so well for me presently.
