Ultrachrome in B&W
Ultrachrome in B&W
2002-11-25 by neilhfolberg
I have been using the 7600 with ultrachrome matte black for
several months now. I soon realized that even with custom
profiles, I was never going to get neutral blacks so I purchased
ImagePrint software for the Mac, which is a little clunky, but it
works and their tech support is great. It delivers neutral blacks
with the possibility of adding "toning".  In side by side
comparisons with the Epson RIP, even the color performance is
better with IP - more subtlety and depth in shadows, particularly.
I have watched this message group for a while. There are those
of you who love to tinker and fuss and in this you will find
happiness. But for those of you who are more interested in the
image I will give you this advice: learn to use the technology to
your advantage.  Every printing process has its strengths and
shortcomings, but you can usually take a good process and turn
what you might consider a liability into an asset. in this case I am
referring to the "softness" of the Ultrachrome B&W inkset.  I can
make prints with this process that use a full and delineated tonal
range that rival those beautiful contact prints from 8x10 negatives
printed on number 2 paper done in the 40's and 50's.  They are
perhaps a touch "softer" in the deepest blacks than a print made
on a glossy paper - but they have exquisite range and depth and
very beautiful print color which I have never been able to achieve
in a silver print.
I have used a semi-matte surface silver paper for some years
now which delivers beautiful, soft prints which have a dmax
about the same (perhaps even a touch less?)  as what I get now
with the ultrachrome inks on Hahn Photorag paper. So I am
delighted with this combination.  the paper does have a small
tendency to flake off tiny little spots but since the inks are not
damaged by water, you can spot it with spotone like an ordinary
print.  On a 20x24" print you might find one or at most two little
tiny little spots.  I spray the prints with a fixative like that used for
charcoal drawings and that prevents damage by scuffing.
The color prints are unrivaled by and are superior to ANY color
commercial process in depth, color range, color accuracy,
saturation, subtlety and I think permanence.  I have returned to
working in color because of this printer after years of absence.  I
stopped working in color when the Evercolor pigment transfer
process died.  Only these epson prints rival those evercolor
prints.
For three months, I have had B&W and color epson prints
hanging in a window where they get our bright Middle Eastern
Israeli sun all day long and they have not shown the slightest
hint of fading.  Cibachrome prints will start to fade under these
conditions in around 40 days. I'm using my eyes, not a
densitometer.  This is not a scientific test, but it's the test I've
been using for years.
I did also try the glossy papers and found that the impression of
depth was just as great with photorag and I like the surface
better, but if you take a really good glossy paper like Legion
Photo Gloss you can get results that rival the silvery quality of
Cibachrome without the color casts, crossover and contrast.  I'd
like to get the 2200 just to make smaller glossy prints.
That's all I have to say on the subject.
Neil Folberg
www.neilfolberg.com
Re: Ultrachrome in B&W
2002-11-25 by jim hayes
--- In DigitalBlackandWhiteThePrint@y..., "neilhfolberg"
<folberg@n...> wrote:
<snip>
 There are those
> your advantage.
Wise words. I have been banging my head against my printers for over
two years just trying to keep the ink stable and minimise clogs. I am
ready to give up: I just found an 2200 through a retail store friend
contact and probably will go IP5 as I want to print, not fuss more.
> in a silver print.
Do you have an opinion comparing an UC matte print to a MIS or PT
matte print?
<snip>
  as what I get now
used for
I had more flaking problems then this with photorag. I used William
Turner more and this was also bad. But I must add that the humidity
here is low. What happens after you spot print and frame it, only to
discover that it flakes more hanging on the wall? Or does the fixative
prevent all future flaking? What brand spray do you use in that event?
> prints.
I've been thinking of doing some b&w prints with small areas of spot
color added which IP5 folks tell me is possible IF I run IP5 to print
RGB.
Jim H.
> Neil Folberg
> www.neilfolberg.com
2002-11-26 by neilhfolberg
or PT
> matte print?
NO - I'm not familiar with these.
> used for
William
humidity
only to
fixative
I haven't had the prints hanging yet, but I have been keeping
them in a portfolio case and handling them a lot and they haven't
flaked.
What I can get here - Grumbacher Myston Workable Fixative from
the U.S.
of spot
print
> RGB.
It will work fine - you get perfectly neutral B&W prints using the
RGB profiles in IP, all you lose is the "toner" control.
 Neil Folberg
www.neilfolberg.com
2002-11-26 by jim hayes
<snip>
> William
> humidity
> only to
> fixative
> flaked.
I guess this can be representative of putting print through it's
"paces", flake-wise then. The thing about being behind a frame is that
you'd have to disassemble it to respot it. And worse than this, if you
used plexi instead of glass, the static charge buildup might
contribute to flaking. I put Eclipse behind conservation clear (UV)
glass and usually don't have problems.
Btw, I didn't mean to give the impression that I used a LOT of Photo
Rag, just printed a few samples and gave up. My flaking experiences
were much more with William Turner...but still both papers are made by
same company, and my photo Rag samples had flaking.
> of spot
> print
> > RGB.
Thank you- when buying a new printer, other's observations on how good
it works are crucial. Esp as with IP5 included, this gets pricy for a
desktop.
Jim H.
>  Neil Folberg
> www.neilfolberg.com
