Zone Development Update (longish)
2003-01-09 by Kevin Gulstene
Traditional compensating development techniques for negatives are not
required to produce a good print when the negative is going to be
scanned and not printed traditionally. It is, in most circumstances,
not material to the success of the print whether you use 'normal' or
compensated development (N+ or N-).
How's that for an iconoclastic statement!
My premise was that as long as the negative was exposed correctly for
the shadows (ie the density range of the negative was up off the toe)
it would not matter whether you developed it for a 'normal time' or N-
time or N+ time.
This makes sense to me because of how I believe the scanner and
software work. When you scan a negative and apply set points you are
mapping a density range on the film to a set of numbers (say between 0
and 16383 for a 14 bit scanner), and then mapping those numbers to a
grey scale. For example if the negative's optical density range is
from .4 to 1.8 then if no data is clipped by set-points then the
density of .4 produces a 100% black in the file and the density of 1.8
produces a 0% black in the file. If that same negative had been
developed differently ( say N- ignoring the 1/3 stop more exposure) and
its density range was .3 to 1.5 it would produce the same file. .3
gets mapped to 100% and 1.5 gets mapped to 0%. So the scene brightness
that produced the shadow density value of .3 or .4 produces the 100%
black in the both cases and the scene brightness that produced the
highlight densities of 1.5 or 1.8 produces 0% black in both cases. The
absolute value of the densities produced by the development doesn't
make any difference except perhaps in extreme cases with very high
(3.3) or very low (.5) maximum densities.
I made a simple test yesterday that seems, to me, to validate that
premise. Here was the set-up: I exposed took two rolls of film with
each frame containing the same image. I used the new plusx. The first
roll was at my 'normal' EI 64 ( exposed 1/60s @ 5.6) developed in D76
1:1 for 7:15. The second roll was exposed at EI 40 (exposed 1/60s @
f4) and developed for 5:00 D76 1:1.
As you would expect the 'normal' negative was much denser in the
highlights. I scanned one frame from each film strip on a sprintscan
120 using vuescan. The little density meter in vuescan (for whatever
it is worth) gave a density range of ~.35 to ~1.85 for the 'normal'
negative and ~.4 to ~1.5 for the N- negative. I set vuescan to scan
B&W, 16 bit, Neutral color balance, with black and white points set to
0%.
The two raw scans are different as you would expect. The N- histogram
is offset a little further from the left and was shorter in length
than the 'normal'. The set pointed scans were virtually identical-!!
I made a levels adjustment to each image to bring the white point in to
clip of the specular highlights in each image and the two images are
pretty much indistinguishable. Their histogram data is:
Normal N-
Mean 178 182
Std Dev 52 51.9
Median 198 204
My new zone mantra is: expose for the shadows and let the highlights
fall wherever they want.
It is arguable that a more dense negative is better because the scanner
will extract more data into the raw scan file but that does not seem to
make any practical difference. Perhaps it would if you were to apply
aggressive curves.
