Scanning film with Vuescan - new features
2003-01-11 by Keith Cooper
Hello For those of you who use Ed Hamrick's Vuescan with their scanner and don't check Usenet (comp.periphs.scanners) ... There was a recent post setting out all the requests he'd had for improvements. I quote the message in its entirety. bye for now Keith Cooper Northlight Images http://northlight-images.co.uk And he only charges $40 for the software!! The address for comments was usenet@... ---------------------------QUOTE----------------------------------- Here is a summary of the suggestions I've gotten by e-mail in response to this thread. In summary, people seem to be most interested in User Interface improvements. It was surprising to me that there was only one request for a TWAIN driver and no requests for a Photoshop plug-in. There were lots of good ideas in these e-mails, and I'd like to thank everyone who sent suggestions. Regards, Ed Hamrick User Interface -------------- 5 Black/white point setting like Photoshop 4 Interactive (randomly placed) batch scans on flatbed 2 Make VueScan scriptable (or have command line options or AppleScript) 2 Add Refresh button Set black/white point before brightness adjustment Use dockable windows Use wizard for advanced workflow suggestions Add black/white point padding option Fix problem with window resizing (on some systems) Change cursor to hourglass when busy Display histogram from selected area Make "beep when done" apply to "Image->Refresh" Combine Filter and Color tabs Context sensitive help Eliminate option types, move advanced options to their own tab Customizable toolbars See all thumbnails at once Use multiple icons for image rotation Improve user interface Two preview images - one before corrections, one after Eliminate command menu (use buttons instead) Change to "Page setup", "Print..." and "Print one copy" Use hotkeys to cycle between frames Add TWAIN interface Add option to set automatic cropping for each preview, even if set to manual Allow seeing RGB and infrared exposure, even when not locked Put last file written in status bar Move "Files|Disk file name" to Files tab Display name of current .ini file, use (modified), change color of changed options Add Refresh button Put basic/intermedite/advanced in each tab (use checkbox for advanced options) Create thumbnails when batch scanning Features -------- 2 Option for strength of descreen filter Use ICC profile for scanner Allow attaching scanner profile to raw files Apply gamma correction to raw scan files Add option for a gamma 1.0 color space Raw scan files with ICE applied Save files in LAB color space Use Photoshop curve files Color wheel feature like HP SmartScan Better handling of underexposed negatives When scanning raw files, make output file same number as input Add option to increase color saturation Support saving PNG files Small-angle image rotation Option for storing non-default options in comments field in files Allow remote scanning (over network) Improve Infrared cleaning Command-line option to specify raw scan file Display black point pixels more clearly in histogram User's Guide ------------ More robust User's Guide More verbose in message boxes and User's Guide Produce PDF version of User's Guide Produce index for User's Guide Give roadmap to identify film from color markings Performance ----------- Speed up scanning, especially when filters used Multitasking - scanning and processing at the same time File locations -------------- Put .ini file in each user's Preferences folder on Mac OS X Put .ini file location ($HOMEDIR/xxx) in system-wide file (like serial number) use ~/.vuescanrc on Linux save multiple configurations in ~/.vuescanrc Allow installing to different directory on Windows Film support ------------ 2 Better negative support for Fuji Superia etc More predefined film types More black/white film profiles Allow users to create their own film profiles Allow manual adjustments of key film parameters Allow entering a floating point number for slide curve Scanner Specific Features ------------------------- 2 Automatically determine frame offset on LS-40/LS-4000 strip film adapter 2 Separate RGB channel adjustment for analog gain on Nikon Auto power-down of scanners (especially Epson) Automatic detection of film borders on Epson 2450 Improve scan quality on Epson 2450 Option for "slow scan" on PhotoSmart S20 LS8000 trilinear support Support Microtek 5900 Don't let Nikon film strip auto-eject if doing long-running processing
