Re: [Digital BW] Split Tone Effects
2003-01-09 by Jerry Olson
Assuming you are using Paul Roarks curves, (He has 5, from cool to warm,
with the MIS VM Inkset), you would select the area you want to be warm,
and with a photoshop adjustment curve, make a curve with his warm curve.
Then inverse your selection, and make another adjustment layer using his
cold curve. Resulting print will be part cold and part warm.
Jerry
"nsams2002 " wrote:
> Could I get a definition/explanation, please, of "split tone
> effects."  Thanks in advance.
> Norm
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
> - Good manners are required at all time. No personal attacks or "flames."
> - Before posting a question, search the message archives and the various resources on the homepage.
2003-01-09 by Shilesh Jani <shilesh.jani@smith-nephew.
To keep the trasitions fairly gentle, you may want to "feather" the
selections before applying the curves.
Regards.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jerry Olson
warm,
warm,
curve.
using his
> Jerry
> > Norm
is at:
header.
&amp;amp;quot;flames.&amp;amp;quot;
2003-01-10 by Paul Roark
Norm,
>Can someone please give me a definition/explanation of
>"split tone effects."
Basically, a split-tone uses cool/neutral ink in one area and warm ink in
another area.
I have a sample of a split tone at:
http://home1.gte.net/res0a2zt/Whalers.html
However, with my monitor the effects of the two tones is hard to see.
http://www.PaulRoark.com
2003-01-10 by Mark Tucker <mark@marktucker.com>
Another way to do split-tone, when using a color inkset, is, in
Photoshop, with your BW image in RGB mode:
Choose SELECT>COLOR RANGE, and then choose
MIDTONES. Go into one of the individual color channels and with
LEVELS, slide the middle gamma triangle one way or the other.
Then DESELECT that selection, and repeat the process, but this
time choosing HIGHLIGHTS, and then swing those tones a
different way, with a different color channel. With HIGHLIGHTS,
you might even use CURVES instead, and pull down the
highlight so that it contains some tone now.
The variations are endless. But the splittone effect is easy with
this method, (if you're using color inks, 2200 etc).
-MT, http://marktucker.com/
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul
Roark" <paul.roark@v...> wrote:
> Norm,
warm ink in
> another area.
see.
> Paul
2003-01-10 by Editor P.O.V. Image Service
Paul Roark wrote:
>Norm,
>another area.
It's pretty clear on mine Paul.. Very emotionally mixed print, love the
warmth of home juxtaposed to the danger/moodiness of the ancient forest
- great piece!
Keith
"Just some guy," and caretaker of the Multiverse's largest EPSON printer
User Community (highly recommended by Vogon Poets and MegaDodo
Publications), at:
http://groups.yahoo.com/group/EPSONx7x_Printers/
"For the rest of you out there, the secret is to bang the rocks together
guys"
{ The P.O.V. Image Service Website is still at http://www.p-o-v-image.com/ }
