Re: [Digital BW] Re: 2200 IP5 Grayscale
2003-01-17 by Jerry Olson
Hi Andrew.  I have made a couple comparison prints between 2880 and 1440
DPI using Hextone inks, and the 2880
was just a hair sharper and smoother. Couldn't see ANY dot pattern in
either print. Yes, it does appear to be a marketing thing,
but I still feel the 2880 print was just a hair better. Of course we are
picking nits here. And yes, it took much
longer to print.  I'd only do it for absolute maximum quality; you'd
hardly ever need it in routine printing.
Jerry
Andrew Rodney wrote:
> on 1/16/03 9:45 PM, jim hayes:
>>A few days ago Colorbyte e-mailed me an update which allows mat paper
>>printing at 2880 (even though it looks as if it's available in the
>>pull down). No profiles for mat paper at 2880 exist yet AFAIK though.
> You do NOT want to print at 2880. First, with IP or the Epson driver it
> takes forever but worse, you lose variable dot dither. The 2880 is IMHO more
> a high figure to look good to marketing than anything else. Print with IP at
> 1440; you'll get a better print and in far less time.
> Andrew Rodney
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
> - Good manners are required at all time. No personal attacks or "flames."
> - Before posting a question, search the message archives and the various resources on the homepage.
[Digital BW] Re: 2200 IP5 Grayscale (Andrew)
2003-01-17 by jim hayes <jimhayes@frii.com>
Yes Andrew I had heard on this list, I believe from you about the 2880
vs 1440 variable dot thing, and I assumed it certainly applied to the
1280 and 1160 printers.
But I wasn't sure of the 2200 on IP5 RIP.
I sent an 8x10 print through at 1440 and at 2880 (although I didn't
have an actual profile for 2880 at the time-I do now). 7 minutes for
1440 and 15 1/2 minutes for 2880.
I did notice one positive thing to the slower speed, even though I was
using the wrong profile: mottling on Eclipse paper is less. However I
am about to get 90% ink reduction curves for this paper and hopefully
this will cure the mottling at 1440. I was using 95% ink reduction and
it helped much over the standard 100%.
Colorbyte now has 2880 profiles for Photorag posted on their site and
they are just finishing ones for Eclipse Satine. From what you say, it
sounds as if I should be just using the 1440 90% ink reduction on
Eclipse. The Photorag seems fine without reducing it's %ink.
One other question: do you know if IP5 prints at 1440 x 1440 or is it
somethiing other like 1440 x 720? TIA
Jim H.
paper
though.
driver it
IMHO more
with IP at
> > Andrew Rodney
at:
to keep them short.
header.
&amp;amp;quot;flames.&amp;amp;quot;
Re: [Digital BW] Re: 2200 IP5 Grayscale (Andrew)
2003-01-17 by Robert Morrison
Jim,
Just to clarify...the mottling problem that you are having with Eclipse and
the 2200 is a problem with gray pigment prints...correct?...because I
haven't seen a mottling problem for color output with IP and the 2200.
Robert
On 1/17/03 10:48 AM, "jim hayes <jimhayes@...>" <jimhayes@...>
> Jim H.
> paper
> though.
> driver it
> IMHO more
> with IP at
>>> Andrew Rodney
> at:
> to keep them short.
> header.
> page.
> them short.
2003-01-18 by jim hayes <jimhayes@frii.com>
Yes Robert. In fact I've only done one print to try to get it to show
up, so I wasn't really trying on the color end. But I didn't see
anything there on the one sample, FWIW.
I just received both color and b&w profiles for Eclipse at 95% and 90%
 ink reduction. The 95% color curves are for 2880 if your interested
in that, and the 90% color curves are for 1440. I also got grey curves
for 100, 95, and 90% at 1440, and grey curves for 2880 at 95% ink
reduction.
So there's lots to play with now for Eclipse (!!). I suspect if you
asked Colorbyte you could get the downloads if you wanted to run more
tests.
I won't know if the new profiles solve my mottling for greyscale. I
need to let my samples dry for a day or three. Right now the 90% at
1440 looks best.
Jim H.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Robert Morrison
<rmorrison@p...> wrote:
> Jim,
Eclipse and
I
2200.
> Robert
> On 1/17/03 10:48 AM, "jim hayes <jimhayes@f...>" <jimhayes@f...>
2880
didn't
for
was
However I
hopefully
and
and
say, it
it
> > Jim H.
> > paper
> > though.
> > driver it
is
> > IMHO more
Print
> > with IP at
> >>> Andrew Rodney
page is
> > at:
messages
> > to keep them short.
subject
> > header.
Polls and other
wish to
this same
> > page.
to keep
> > them short.
header.
various
2003-01-18 by Carolyn Frayn
Andrew, I compared the 1440 and the 2880 settings on my 2200 - there is
a difference to my eyes.. The 2880 appears sharper, has a little more
depth, and above all is much less magenta in the mids than the 1440
print.
Carolyn
>> it
>> IMHO more
>> with IP at
>> Andrew Rodney
