Eclipse Satin paper question?
2003-01-30 by Jim Panzer
I recently purchased some Eclipse Satin paper from Inkjet
Goodies, the paper weight it 100.  I also have some 190 weight too for final
printing time, the lighter stuff I will generally use for proofing.  My
question is, if I get a print to look good on the thin paper, is it going to
look the same on the same, thicker, paper?  Does paper thickness affect the
final print?
Thank you!
Jim
Re: Eclipse Satin paper question?
2003-01-31 by johnkaplan <kaplan@writeme.com>
-I think that's a good question, Jim. In my experience, The Eclipse Satine
paper stock is much smoother in the 190 weight, without much texture to
speak of. Once they jump up to the 300 weight, it is highly textured and each
side is quite a bit different, despite the claims that it can be printed on each
because of its double coating. This hasn't caused major problems but the
texture can definitely add a clumpy look to a smooth sky or skin, for example.
It does bug me although the paper otherwise prints very impressively. I
wouldn't shy away from the Eclipse, it has many fans. However, if cost is no
object, the Hannemule Photo Rag never disappoints!
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jim Panzer <
> final print?
> Thank you!
> Jim
