Black only printing on a Canon S750
2003-02-09 by jeades947 <jeades1@sc.rr.com>
I am using a Canon S750 and I have discovered the wonderful world of black Only printing of photographs; or so I thought. I was running out of color cartridges too fast and found a newsgroup called DigitalBlackandWhiteThePrint@yahoogroups.com and have learned a lot. I read many of the messages and logged on to many websites mentioned in them. As a result, I discovered http://www.cjcom.net/digiprnarts.htm which dealt with using only black ink for printing the images. It is a learning curve, I admit, but I buckled down and worked with it over the course of a few weeks till I became familiar with the technique. I started print images and noticed almost all of them has some color cast to them, but I chalked it up to the ink and paper combination. Today I got a screen message from my printer that my Cyan and Magenta inks were running low. I wondered how this could be possible because I was using only black ink; or so I thought. Going back over everything carefully, I reexamined a vital printer setting I thought would not be necessary to set initially. One toggle for color management was "Auto" and "Manual" and I had it toggled as "Auto". Changing this to Manual did not seem to make any difference in the color cast of the prints, and now I am running out of color inks. If I take them out, the printer won't print anything on the paper at all, or if I tape over the ink sensor it won't print at all. Has anyone else had this same problem and solved it? If so, please send me email directly jeades1@... or you can post it on this newsgroup so all can benefit from your knowledge. Thanks in advance for any and all help you can give me with this dilemma.
