> So the workflow would be the following: Scan the B/W-Negative as 16-
> bit RGB, make the adjustments in PS and then print it in Photoshop
> (as 8 or 16 bit?) with "PowerRIP Stylus Photo 1280" (or PowerRIP
> PDF?). When I go to "properties" (I hope this is the english word for
> the options you can change before printing the picture) there are
> several options like Color Control, Halftoning, Color Control and
> Postscript output Format. Can you suggest me the settings for these
> options?
I just leave everything at default except DPI and paper/inktype. I
think most of the other options are probably only interesting if you
have specific needs for Postscript output.
> Other than that I make no special adjustments. I made a
> > curve that I find useful for matching a 21 step wedge to a reference
> > card, but for real pictures I usually don't use it.
> > The MIS inks will probably give you the best prints though.
> So PowerRIP works with the MIS Hextone inks and will give better
> results than one of the Workflows on the MIS homepage?
No, I don't think you need PowerRIP at all. Try one of the workflows
instead. PowerRIP is probably only useful to someone who wants to get
rid of metamerism on the 2100 printer, I can't really see any other
use for it for printing photographs. But since you already have it
installed, maybe you could give us some feedback on what the prints
look like on your 1280 compared to the Epson driver?
> Sorry for the Newbie-Questions!
No need to excuse yourself, we're all here to learn :)
